Yesterday I did some shopping for my R32 GTST and i was recomended a link plug in ecu because apparently its very hard to find a power fc d-jetro for R32's. and cheaper too. $1500 for the link and $1800 for the PFC.
The link does have the map sensor instead of the AFM same as the PFC.
Please help as I have no idea which to choose. I always thought PFC was the way to go but now I'm just confused. I could have sworn that I have seen D-jetros going for 1400 but can't remember where.
I was also told if I am installing bigger injectors, I need to install these little things(sorry.... can't remember the name of them) in the injector loom because the standard inj's are low imperdance. Is this true?
Thanx
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/
APEXi - Power FC & Hand Controller - D-Jetro
BNR32/33 89/8 - 98/12 D-Jetro
414-N026
AU $ 885.10
APEXi - Power FC - D-Jetro Option parts
D-Jetro PFC Nipple X 2
499-A019
AU $ 6.89
D - Jetro Harness X 1 GT-R
415-XA04
AU $ 36.77
D - Jetero Map Sensor X 2 RB26DETT
499-X001 X 2
AU $ 290.19
Order Total
AU $ 1,218.95
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2574455
Thanx
Depending on your power target , you might want to consider a third option. Get your standard ECU chipped and tuned. Then I would consider a "normal" Power FC.
:P cheers :P
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2574469
414-N026
AU $ 885.10
499-A019
AU $ 6.89
415-XA04
AU $ 36.77
499-X001 X 2
AU $ 290.19
Order Total
AU $ 1,218.95
But he has an R32 GTST??
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2574526
Ask Paul from Performance- wise.
He has a group buy going on all the time.
http://www.skylinesaustralia.com/forums/in...howtopic=132176
He will be able to get you a better price. :P
Go to the buy it know area and read on..it has some things in there that will interest you.
http://www.skylinesaustralia.com/forums/in...howtopic=124512
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2575050
Another quality post buddy.
damn right a quality post - who with half a brain quotes $1800 for a powerfc ?
My comment still stands - Bullshit.
But wanting a D Jetro does cause a few issues - I'd be going by SK's post, or just getting a standard powerfc with a Q45 AFM if you need the extra flow. I have a q45 and it works a treat with my powerfc. Unless you want a huge ass vent to atmosphere BOV, then the AFM won't do you any favours... But why would you want that?
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2575643
GTS Link has, launch control, boost control, closed loop, active knock sensing, laptop or hand control tunable and is map sensor based.
Not a bad unit at all.
Agree 100%, i have had a link in my 33 gtst for around 2 years and it's never skipped a beat.. it has tunability for all my mods (and future ones) and more, launch control is a great bonus, and laptop tuning and data logging was a big plus for me when deciding..
Don't know all the ins and outs for the PFC so i won't comment, they've been tried and tested and have seen awesome results on heaps of cars, i've also seen the same from link ECU's and thats what i have so my bias leans towards Link.
As with the prices, both the PFC and Link can be had for cheaper than your original prices, it's just a matter of looking around..
Cheers, ultimately it comes down what ever fits your needs best... good luck
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2576524
I agree with SK, ECU retune is the go with a R32. But looks like the Link ECU has some good extra functions if you need em, can you tune it with a AFM?
A car with a AFM will give you a more precise tune than one with a map sensor, better throttle response etc.
cheers
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2576727
Mafia I said the same thing, nearly fell over when he told me 1800 (advan).
I'm still yet to try performance wise. Thanx 700hp.
sorry paulr33 I forgot to mention that part. A P engineering.
The reason why I want the map sensor PFC is from the stupid vacum spring thing that was mentioned a couple of issues ago in HPI. Its pretty bad. I'm not fussed at all with the bov, it was cool when i first got it but I got over it pretty fast so the plum back is back on it. It doesn't stall but it gets close still. Nothing wrong with my AFM either, tested with another one and got a new one for peice of mind and its still the same. New plugs, silicon hoses, coils, etc. no air leaks.
Sydneykid, I was considering doing the chip and tune to my ECU but I really want the most I can get. And its not just that. A few friends of mine had there STD ECU's chipped and tuned and then later purchaced a PFC. It wasn't the power increase that made them happy, it was the way the car drove and responded after the PFC. I don't know if this was true because I never drove the car before and after myself so I really don't know if they are just full of it or not but hey, if I can get more power than I'll take it.
As RB30 said, the link doesn't sound too bad at all but I can't seem to find many people with one and I really don't want to just take the salesmans word for it.
Snoman you are the first person to give me hands on info about these link ecu's. Where did you get yours from cause advan performance seems to be the only place that has these, but then again, I've only been looking for a day or 2. Did you get the plug in, wire in, link, or link plus? I think the one I was shown was the Link plug in so I don't think I get launch and boost control. If you've got the wire in what did you get charged to install it? Does the link affect the speed sensative steering as I've heard the PFC does?
Anyone heard about the little things that should be installed when upgrading 32 GTST inj's? He said something about the std inj's are low imperdance so they are a must apparently.
I didn't know that Munna1. Thanx
man I'm confused now
sorry about the late reply. I'm on night shift this week.
thanx.
Edited by ROB32T
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2576884
I need to get a AFM witch u think is better Z32 or Q45??
https://www.sau.com.au/forums/topic/138204-pfc-or-link-ecu/#findComment-2576902
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
