235/45/17 has a massive range of tyres, and they are quite well priced due to the massive popularity.
They are also the size of a control tyre for one of the motorsport events, so its relatively easy to find new and second hand Comp-Rs in that size.
  • Replies 42
I'd have to agree with that
Semi's are probably fine for the street 98% of the time, but the other 2% (Or maybe 1% at the moment with this drought) when you have some serious rain they would be downright dangerous.
Best to go for something that's a bit more of an all rounder.
any idea what semis in that size go for?
I bought second hand Advan A032Rs in 235/45 R17 for under $100 a pop. Mind you, they were very second hand. Track days only, and only if you're not doing competitive motorsport. On the plus side they never overheat and even after a couple of track days / supersprints they don't look any more worn than when I got them.
If you buy brand new RE55S, A032Rs, R888s, etc you're looking at $450 a corner.
Being a street car, i wouldn't want to run semi's on it.
I wouldn't recommend it, either. I've driven on Comp-R semis as daily driven tyres, and since it was winter it was one of the scarier times of my life. In the wet I may as well have been on ice....and what do you know it was always raining.....
I would suggest keeping your OEM rims. Find good tyres that are as wide as possible that will fit your rims while retaining the OEM rolling diameter.
Check the tyre thread for feedback, and then see what falls into your budget.
Well I wouldn't put 225/50 on a 6.5" wheel... but Yokohama thinks it is ok (6.0-8.0)
Mind you my car has 215/45R17 on 9J (7.0-8.5 recommended)
http://www.yokohamatire.com/utrimwidth.asp
Choosing a wheel near the middle of the range will give a balance between ride quality and handling. A wider wheel will improve handling at the expense of ride quality, while a narrower wheel will improve ride quality at the expense of handling. Consider these compromises when selecting wheels.
So the answer is YES, or NO... depending on what you mean by better or worse :)
Edited by Laurence
tyreflex
less tyre flex makes it more uncomfortable but makes the car a lot more predicatble.
but once you start stretching tyres enough, you are sacrificing the amount of tyre you are gettin onto the road for small difference in tyreflex.
most people do it for the look
Edited by salad
Just to add my experiences:
1. 265 wide FALKEN 326(SHIT TYRES) on 18 x 9inch rims like NEW! 95%+ thread <265/35/r18>
2. 205 wide Dunlop Sp2050(OEM Accord Euro Tyres) 30-40% thread just above wear indicators on Stock 16 x 6.5inch rims.(r33gtst) <205/55/r16>
Car with 200rwkw. R33 gtst.
1. Around Wakefield i managed the same time around the track both 1:18 BACK then (1:16's now).
2. Traction wise, i was surprised some quality dunlop tyres with only 30-40% thread GRIPPED better then my near new 265 falken tyres. 95%+
3. Compared to my 225/50r16 falken 326(compliance tyres that came with car). the 205/55/r16 dunlops is 100 TIMES BETTER.
So for me, QUALITY tyres OVER WIDER tyres.
<btw my mate just picked up some Toyo T1R's a few months ago in 205/55/r16 for $170-180/tyre> for the 225/50/r16 is was like $210 or there abouts.
thats just my 2cents.
salad... could you explain the theory on less contact on the road.
Does the tread go concave or something along those lines?
when you're stretching a tyre on a rim, you are using a skinny tyre that is too skinny for the rim. ie, not very wide. so you could get a much wider tyre on such a rim.
just a commonly used example, a lot of people stretch 215/45R17 on 17x9, ive done this too. now, with a 9" rim you can fit 255/40R17 on there no worries. now going by the rule of thumb that the width is in mm, you now have ~19% more rubber on the ground. thats a fair bit!
given you will have a bit more flex as the sidewall is slightly taller (5mm) and you arent stretching it, but i would rather go for the more grip personally. even for drift, means you have more grip and can go a lot faster, and hold bigger entries.
on standard rims i've run 225/50 and 205/55, and i liked the 205/55s much better. given it probly wasnt a fair test because i ran good yokohamas in the 205/55 and run of the mill 225/50s, but the 225/50 just felt a lot sloppier
Edited by salad
the contact patch thing is a myth. force is pressure times area, and the pressure a tyre can exert on the road is equal to its internal air pressure. therefore no matter what shape of tyre (wide or skinny) you will have the SAME area on the road.
However, a wider tyre will have a wider patch and a skinny tyre will have a longer patch. wider patch is better for cornering grip, skinnier patch is better for driving in the wet as there is less water to push out of the way.
Yep got that idea now. because the tyres still have the same amount of weight pushing down on them. A skinny tyre will have a more square shape contact patch, whereas a wider tyre would have a rectangle one.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
