Depends.
Expect the car too have had some accident damage, but really, if there is no chassis or alingement damage then who cares.
- Obviously you'd care if your after a show car.
If the chassis is fair then most everything else is replacable. You just need too factor in the cost (and labour if you can't do it yourself) too bring the car upto standard.
Personally, if you after a car your going thrash, do track days in, then I'd be looking for a bargin high kay car and bargin the owner down too a cost where you can afford repairs.....
Good Luck.
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578152
Have a look around the forum. Particularly the stickys in the various sections. You will learn a lot.
Basically 98% of them are wound back. A 1989 GTR with 40,000 less k's than my 1999 GTT? I don't think so.
You buy on a condition based appraisal. That's why with imports it's worth having them checked out by a workshop that does work on these types of cars regularly. If it costs you $1000 in workshop inspections before you find one and then you end up NOT rebuilding the engine, you have saved yourself at least $6000.
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578174
Depends.
Good Luck.
Would you buy something stock or a car with bolton mods if you had the choice ?
Thanks for replying
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578200
Have you got any idea of where I could locate a good repairer who offers pre purchase appraisals of GTRs in Perth ?
Thanks for your reply
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578210
Low km GTRs exist. Granted mine is a 1997 model but it only has 32k on it. :( Knowning who owned it since 1999 helps verify that though.
If you are unsure check seats, steering wheel, handbrake, pedals etc for wear. It's pretty obvious when a car has done a lot of kms. Low km cars from Japan are around, I imported a 1985 RX7 with only 45k on it, was practically brand new under build up from being unused. You just have to be careful and know where to look.
The one in the trader for $18.5k with 128k on it looks nice, tidy and honest.
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578243
or demand 6-8 grand off the price......if they don't agree.....walk away....
once you get the car take it apart and rebuild it with that 6-8grand.....sit back and relax and never have to worry about broken engine again.....:(
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578244
I have heard that if the plenum chamber is not flaked and missing paint that it is a good sign that the motor has not seen high kilometres. Would anybody have any other views or experiences?
Yeah I have seen a few that have been resprayed. They have often been done badly so is easy to pick (can see where different layers of paint begin and end).
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578279
what other components would you repair ?
A lot of other things that are perishable and wear out over time... Time isn't kind to all sorts of parts to cars. Can happen with kms on them or not.
Edited by GT-R32
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578316
I wouldnt buy a 32 from Japan in todays day.
Its just too risky and can end up costing you a lot more.
Buy something thats already here, that you can have inspected by a local expert. You stand a better chance of getting a good car that isnt clapped out that way
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578741
one of the 1988 cefiro's we imported came with 12000kms or so on it. It also came with a log book that had been filled in at the same Nissan dealership every 6 months (hehe was odd, their seal changed as the Nissan logo evolved). It even came with the factory lace doileys and original purchase reciepts etc in the owner's name.
Was such a bizzare car... we didn't believe it so we had a mechanic go check the car while it sat in japan, and found that it actually was hardly ever driven... So the rare ones do exist.
Not necessarily, the paint flakes off as its not bonded well to the plenum from the factory. Simple heating and cooling causes it to seperate, regardless of the km's its done.
Basically as the guys above stated, go by the condition of the car, don't believe the kms. If the car is in Japan, get it inspected first, if its local, then take it for a test drive from a cold start. Take the car to a mechanic who works on GTR's to have it inspected.
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578775
I have a car lined up with a knock in the bottom end and the mechanic selling it says I have a choice of a low km engine or a reconditioned unit from Japan . He will install engine and repair minor rust spots .Its got 17inch aftermarket rims ,adj coilover suspension. Does this sound like a better option than a Jap car?
https://www.sau.com.au/forums/topic/138442-low-k-gtrs/#findComment-2578782
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
