Can anyone help? Started having some problems with the gearbox or transfer case. When i drop the clutch a little harsh theres a loud crunching/grinding noise. Happens in any gear if u pop the clutch too quick.
Also not sure if this is related but the 4wd torque split guage reads a slight amount of power being sent to the front wheels when cruising at speeds over 60kph.
Any ideas?
https://www.sau.com.au/forums/topic/138597-4wd-problems/
Any ideas?
NOT normal. I cruise at 110 (ish) for hours at a time... I'd wear out my centre clutch if it did this
check your tyre diameters - they should be the same. The fact that this only happens at speed makes it likley this is the issue.
rsvp
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2586039
rsvp
When I am cruising, my torque gauge always reads that there is some split to the front as well. If you accelerate, the amount becomes more. I was under the impression that this was meant to be the case. Can anyone confirm this, or set the record straight?
My tyre's are all equal - not differing sizes.
Cheers,
Dan :)
Edited by R32 GTR PWR
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2586715
Definately not normal to have torque cruising in a straight line....front torque is based on either difference in wheel speed (ie wheel slip, different sized wheels or maybe different wear front to rear) or the reading from the longitudinal accelerometer....ie when you are accelerating strongly.
We have never really measured what "strong" acceleration is for the standard computer, but if the sensor was not mounted straight (ie on an angle) or the rear of the car was lower than the front, it might read as acceleration all the time.
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2587574
If it is not normal, and I am to assume that there is a fault with something on my car (ie sensor mounted incorrectly) what is the best way to confirm this? Can you help as to where the sensor is and how it should look/be mounted? Or perhaps someone/somewhere that would know?
Thanks in advance,
Dan :(
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2588837
Hey,
on my 32 GTR, there's no drive to the front while cruising. I understand that because of preload
the 33s and 34s are different.
Note that even if there _is_ drive to the front wheels (say, 50%) as long as all the wheels are
rotating at the same speed there should be no wear on the clutch packs...
Regards,
Saliya
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2589104
there shouldnt be any movement oin the torque guage while cruising, its was intended to reduce rear wheel traction loss, thus it doesnt engage massivly, only gradually unless the clutch is dumped.
ive noticed if u r cruising and u hit a big bump or somthin on the road, it engages the fronts and stays like that until u let the accelerator go. then it drops
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2590531
Unless you want to turn the front wheels to any angle other than 0 degrees... then there is wear, be the diff open, limited slip or locked (??).
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2590728
Cheers,
Dan :P
when I put new tyres on the front took it for a hiway run and at 100k I could feel the car surging, looked at the torque meter and it was pulsing up to about 10% same frequency as the surging, went back to town and took notice of the torque, on gentle acceleration big torque was dialing up so drove to the tyre place and got new rears, viola back to normal no surging and only see torque under hard acceleration or wet roads never on cruise.
the manual quotes the maximum tyre diameter difference allowed i will look it up i ur interested.
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2594670
my R32 GTS4 always showed zero when cruising, only ever showed torque to the front when accelerating or rears spinning. Never had any probs with the 4wd system in the 180,000kms the car had put up by the time I sold it.
Perhaps the additional power/heat generated by the GTR is reducing the performance of the transfer case fluid. Don't the AU sold GTRs have additional coolers fitted for the transfer case?
Test Scenario;
1 - gauge is incorrect
2- clutch pack activated too early
- incorrect transfer fluid viscosity
- old/contaminated fluid
- wrong fluid
- insufficient fluid level
- attessa pump system not releasing pressure from previous
activation
- G-force sensors giving wrong readings causing early activation
- Tyre diameters don't match giving computer impression wheels are
spinning.
Maybe its the gauge playing up, you could try removing the 4wd fuse which will cut out the 4wd and the abs for a bit to make sure the gauge can read Zero. Check the site for particulars on doing it.
IF the gauge is working correctly then somehow the car is activating the the FWD - maybe fluid is old and thicker and changed viscosity is activating the clutch packs - a fluid change is in order for the transfer case.
maybe there is the wrong fluid type in transfer case which is activating the clutches due to incorrect viscosity.
maybe fluid level is low and clutch packs are heating up and gripping
Is the attessa fluid level correct - check the resovoir in the boot (RHS) with the ignition on. See workshop manual for correct operation.
Other than that remove the centre console and have a look at the g-force sensors, from memory they will show if they have been subjected to a hard knock - see workshop manual for particulars.
A bit too check but the gauge should be zero when just cruising.
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2595112
Thanks for the helpful input guys, this is what I have found so far:
With 4WD fuse out the car reads 0 (as you would expect).
The tyres are all 17's HOWEVER, they are differing brands with, you guessed it, slightly different diameters.
So know I am going to try and get two changed to the same size, or put 4 tyres the same on to test.
The smaller ones are at the rear. If I put them to the front, would that help/change the situation?
Cheers guys, I keep you updated on progress.
Dan :laugh:
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2595819
Actually I did at one stage put new tyres at the front and and old tyres at the back and i had no problem. But with old at front new at back i had the problem. You can try swapping them around first
Dan :D
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2596368
mine does this for some reason too...after changing to a new set of rims...i think it could be the tyre diameters arnt the same...not as in width but diameter, will have to check. Had track day not long ago and put on the old rims with semi slick on the rears and didnt show a reading at all while just cruising.
Would this be really bad for the clutch pack in the transfer case with it having some load on it while cruising?
https://www.sau.com.au/forums/topic/138597-4wd-problems/#findComment-2598816
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
