hi
thinking about upgrading my turbo
need to go as high as 800hp +
fast spooling when use with rb30
which brand makes good turbos without raping the wallet ? may be something that can compare to a HKS To4Z or T51Kai ??
How are the pricing for turbonic turbos ? are they cheaper then HKS and the quality as good ?
when i look at a turbo sizing, how do i determin what kinda power out put it has ? how do i tell how fast it will spool ?
thx
__________________
https://www.sau.com.au/forums/topic/138829-single-turbo-help-800hp-goal/
800hp @ the wheels will never spool quick even on a rb30
a T88 could do that but your wallets gonan get a raping
is this gonna be a dyno queen or actually driven daily/track/drags
how are you going about with the Rb30? parts, rough price, which workshop? im lookin at getting one built with a rb25 head (been quoted between 7k to 10k by various workshops, sound approx right?)
Will be looking at t51R spl on about 45psi boost, no i am not joking. or Turbonetics Y2K on a bit less. I looked at the Y2K but the smallest exhaust housing is still way to big. this will definatily be a track car only and expect to run atleast 100 gas to spool it on the brake.
hi
thx
__________________
hi
i am not looking for a twin turbo FAST SPOOLING, but i just wana compare, which is faster between these single turbos..
i am planning on a Track / street car...
Gary "sidneykid" is building my RB30 with a 900hp compatible range.
head is only 272cams + tomei springs and retainer kit and valve guides
turbo is T78..but looking to upgrade, greddy in-plenum.
etc...
Have many people on this forum tried getting tricky and using one of those MrTurbos cores? This guy, in Sydney i think, makes CNC cut watercooled ballbearing cores and shafts, which give you almost any choice of turbine and compressor combo!!
I saw some scary 1500hp setups using his cores, advertised in an American sports compact mag few weeks ago as well.
I know of at least one person lurking on these forums with one, are there any others? What did you use, how did I fair compared against stock unit?
- M
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
