Not sure if this is the right place to put this but..
Ive read somewhere that petrol loses its OCTANE level after a period of time.
So approx how long does this occur? Is this true?
For example I fill up the car with BP Ultimate 98RON, how long will it take to "expire" and lose its "98RON" properties?
Is it bad for the car if there is fuel in the tank from like say 6 months ago?
Cheers
https://www.sau.com.au/forums/topic/138836-petrol-expire/
I'd leave fuel in the tank, an empty tank tends to rust.
And some light reading on the subject:
http://www.chevron.com/products/prodserv/f...detecting.shtml
http://www.virginiawind.com/tips/gasoline_stabilizer.asp
http://www.challengers101.com/FuelStorage.html
The last one is the most generally informative. I was looking for a deterioration duration curve [time vs decay] but couldn't find one.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2585746
less wh0ring more explaining.
maybe around two weeks it would drop a bit of its just sitting there in the tank?
Hmm interesting.. thanks Paul! :)
Mate works at an Audi workshop, they had a car sitting for 2 years and someone tried to start it. The petrol had thickened and needed new lines and pump as they were all clogged up.
lawl two years
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586284
a friend who used to run a local servo a few years back said it drops octane even while sitting in the tanks at the servo. so servos that dont do as many customers, fill up less often, are likely to have lower octane fuel than a busy store than fills up reguarly
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586327
Official word from Shell is that their fuel will be stable if stored up to one year, as long as the storage conditions are "adequate" - ie the containers are full to minimise exposure to air, tightly capped, out of direct sunlight, and under 27°C.
underground tanks at servos don't even fulfil those requirements. And vented petrol tanks in cars that get nice and hot sitting in the sun and cool down again at night certainly don't, so the fuel deteriorates much faster than these optimum storage conditions in Shell's literature.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586384
The deterioration of fuel is or can be brand dependent. If you read any of the links in my previous reply, it appears that the length fuel can be stored also relies on the preservatives each company uses to increase the shelf life of their brand. I don't know which ones are best, but I wouldn't trust any of them. Its an easy question really: Whats cheapest, a new tank of fuel or an engine rebuild?
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586431
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
