Not sure if this is the right place to put this but..
Ive read somewhere that petrol loses its OCTANE level after a period of time.
So approx how long does this occur? Is this true?
For example I fill up the car with BP Ultimate 98RON, how long will it take to "expire" and lose its "98RON" properties?
Is it bad for the car if there is fuel in the tank from like say 6 months ago?
Cheers
https://www.sau.com.au/forums/topic/138836-petrol-expire/
I'd leave fuel in the tank, an empty tank tends to rust.
And some light reading on the subject:
http://www.chevron.com/products/prodserv/f...detecting.shtml
http://www.virginiawind.com/tips/gasoline_stabilizer.asp
http://www.challengers101.com/FuelStorage.html
The last one is the most generally informative. I was looking for a deterioration duration curve [time vs decay] but couldn't find one.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2585746
less wh0ring more explaining.
maybe around two weeks it would drop a bit of its just sitting there in the tank?
Hmm interesting.. thanks Paul! :)
Mate works at an Audi workshop, they had a car sitting for 2 years and someone tried to start it. The petrol had thickened and needed new lines and pump as they were all clogged up.
lawl two years
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586284
a friend who used to run a local servo a few years back said it drops octane even while sitting in the tanks at the servo. so servos that dont do as many customers, fill up less often, are likely to have lower octane fuel than a busy store than fills up reguarly
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586327
Official word from Shell is that their fuel will be stable if stored up to one year, as long as the storage conditions are "adequate" - ie the containers are full to minimise exposure to air, tightly capped, out of direct sunlight, and under 27°C.
underground tanks at servos don't even fulfil those requirements. And vented petrol tanks in cars that get nice and hot sitting in the sun and cool down again at night certainly don't, so the fuel deteriorates much faster than these optimum storage conditions in Shell's literature.
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586384
The deterioration of fuel is or can be brand dependent. If you read any of the links in my previous reply, it appears that the length fuel can be stored also relies on the preservatives each company uses to increase the shelf life of their brand. I don't know which ones are best, but I wouldn't trust any of them. Its an easy question really: Whats cheapest, a new tank of fuel or an engine rebuild?
https://www.sau.com.au/forums/topic/138836-petrol-expire/#findComment-2586431
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
