Hmmm dosent sound right to me, is the car running very rich for some reason???(is the rear bumper just above your muffler stained black?)
Or possibly your factory petrol level sensor is faulty or something, could also be your oxygen sensors, i would get it checked out at nissan or some other performance shop.
are you sure it wasnt constant spirited driving? i got around 200km's outa my first tank when i first got my R33 GTST. I gave it hell, everytime i put my foot down it went all the way to the floor.
next few tanks i was able to get over 400km's as i started driving it normally, so the fuel usage lies heavily on how you drive the car
firstly, how much fuel are you talking about when you say a full tank? there is no point saying 'full tank' since when some peoples gauge shows empty it has used 45L, others 55L.
convert it into L/100k's. e.g. if you get 217k's to 50L you are getting 23L/100k's. if you only used 20L/100k, and if you only used 40L thats 18L/100k's.
also, what mods does the car have? that could be the key to answering your problems. otherwise it may be either your AFM or o2 sensors.
yeah mine has now started the same problem, I don't drive mine often (maybe once a week if I'm lucky) so a tank lasts a while, but i manage about 260km out of a 40L so i get about 15~16L\100km. When i first got the car i got almost 560km out of a tank (not sure how many litres, was a damn while ago) on the highway coming home from the compliancer. Whats th best way to check if its afm or O2 besides get new ones?
I get 12.5 around town! :O ~360kms from ~45L (as much as I can fit in at the time for the last three tanks). Bloody stoked with that consumption, I expected around 14-15L around town. Worst I have gotten was 350kms out of 47L which is 13.4/100kms. Still bloody good given performance for around town driving IMO.
Before mine was tuned it was going through a tank every few days, it was really bad, but after the tune its fine, average 350-400k's per tank, or way less at trackdays etc ovbiously
Have a check of:
AFM's if your not running a MAP sensor ECU (which it doesnt sound like you are)
02 sensors
Spark plugs
An idea would be to use a MAP sensor ECU, i was advised to do this, and im very glad i did, tuning was a bit more expensive, but the AFM's arent used anymore eliminating that from ever being an issue - something worth thinking about :dry:
EDIT: Also i didnt think an ECU would be worth it for how my car was back then, it paid for itself VERY quickly, but aswel as that, the timing was all fixed up, and there was no more surging - just power where-ever and when-ever :P
For some reason mine eats O2 sensors and runs super rich with them plugged in so I run them unplugged. Might be worth giving that a try.
See how it goes after new turbos, PFC, 044 and 600cc injectors. As it is now it pulls 260rwkw on stock computer with steel wheel stock turbos.
I get 12.5 around town! :laugh: ~360kms from ~45L (as much as I can fit in at the time for the last three tanks). Bloody stoked with that consumption, I expected around 14-15L around town. Worst I have gotten was 350kms out of 47L which is 13.4/100kms. Still bloody good given performance for around town driving IMO.
That's pretty good....
I get between 16-17......
no real difference on the highway (I have got as good as14.6) as it still sucks the juice
car is basically standard
By the sounds of it you have a gts-t? I found my last gts-t wasn;t that bad on fuel even tough i was running 270 degree cams and pushing 270rwkw, did have a map sensor ecu which as said above may make a difference. My stock gtr is worse :mellow:
By the sounds of it you have a gts-t? I found my last gts-t wasn;t that bad on fuel even tough i was running 270 degree cams and pushing 270rwkw, did have a map sensor ecu which as said above may make a difference. My stock gtr is worse :)
LOL :laugh:
yeah it's a gts-t....
pig on fuel, but you get that :ermm:
i have done a lot better with this tank. Cruise back from cooktown to cairns sitting on or around 100-120kph and then a few runs around town and the light has just come on. 445kms so far. that is a little better :)
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
