  • Replies 85
well done fella, where are these pics?
Got the camera out and went for a quick drive to take some but run out of time :sick:
Maybe monday or tuesday :D
Weekends suck badly for me (crosses fingers they dont do the photo shoot cruise on sunday).
Need to wash it again now lol damn black cars :laugh:
How much u pay for ur black R33 man...coz i bought my grey skyline couple months ago, cost me 17,000, thought it was a bit pricey but surprisingly one of the cheapest i cld find..coz i was looking for ones with under 60,000 k's, came with deep dish rims as well, got it from redline, those mof*kas still charge a bit for there cars, even tho they have some very nice ones. Mines an M-spec 1995 got a 3" stainless steel exhaust and a apexi air filter with all the brackets done n stuff for me, just wanted to kno if thats still heaps expensive? :rofl:
Btw where did u end up gettin it from?
Redline as well, payed bit more then you but its 96 and a s2. You can get them cheaper if you import ya self. This time around though I didnt want to wait shrug
Edited by ukai
Ohh noshit yeh, i saw ur car there about 1 or 2 weeks ago i reckon...looked pretty nice man! congratulations bro....btw today is wet and skylines are very scary in the wet, as i found out today (being the first day ive drivin in the wet) heaps of fun tho. be careful ppls :)
hehe cheers man. btw how can i change my engine type or w/e it is next to my log in name
<--------------- it says rb20E but i have an rb25, and i wanna put a foto of my car but i dono how..lol. soz for the stoopid questions
I believe the engine type changes with the number of posts you do. (status thing)
For your pic get you foto and edit to match the size and shape below
Your avatar must be no bigger than 120 pixels by 120 pixels in size. Uploaded avatars from your computer must be no larger than 100 KB.
The following file types are allowed: gif,jpg,jpeg,png
Then goto mycontrols (top right) then click edit avatar settings on the left menu then use the upload avatar dialog box. If ya need more info pm me :)
Looks quite stock, nice ride tho, any pics of the inside? Wont get many hassles from cops if stock, wonder what that would be like.....
Yeah its stockers, only want to do a few minor upgrades my self and thats it. Ill try and take some inside pics or you can see it at the photo shoo meet if you going and they dont hold it on a Sunday :)
hahaha cheers ukai cleared that up for me. I really wanna go on like a Skyline cruise in a week or 2, coz all my mates have commordores or hondas, b good to see skylines representing across adealaide. If sum1 wants to organise one or sumthin IM iN! haha :):)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
    • As I wait for parts to be delivered, I have managed to procure via a contact a R32 Nistune ECU......for now I just want to monitor what the car is doing but eventually.......who knows where we go 😂
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
