Man I'm stupid, finally figured it out. All the pics I keep seeing of the 350gt-8 are the 2001/2002 models. Mine is a 2003 and has had a few changes. I found this on the nissan global site:
Skyline Sedan Undergoes Minor Model Change
Among the refinements made to the Skyline Sedan this time, the 2WD models now have higher spring rates, shock absorbers with approximately 30% greater damping force and larger-diameter stabilizer bars for better control of body motions, compared with the previous models, and thereby deliver a tauter driving feel. In addition, braking performance has been enhanced by adopting a braking system incorporating high-performance sport brake pads with an increased friction coefficient and highly rigid brake rotors with an outstanding heat radiation characteristic.
The exterior design projects a sharper impression than before as a result of applying a smoky chrome finish to the grille and headlamp inner panels and changing the sill color from gray to black. At the rear, the car badge and Skyline emblem have been repositioned to give the rear-end a wider look.
On the inside, the audio and heater control switches have been embellished with a chrome accent for a higher quality image, and the 250GT and 250GT FOUR models are provided with rear-seat air-conditioner vents for enhanced occupant comfort.
The grade selection has also been reorganized as part of this minor model change.
<Major specification and equipment refinements>
Exterior
Repositioning of the rear car badge and Skyline emblem
Refinement of the design of the radiator grille, headlamp inner panels and sills
Addition of Sparkling Silver Metallic and Rose Red Pearl as new body colors for a choice of six attractive colors altogether
Interior
Refinement of the control switch design
Adoption of sun visor extensions
Addition of a light to the front-seat vanity mirrors
Adoption of a double-pivot rear-view mirror
Expanded application of rear-seat air-conditioner vents to the 250GT and 250GT FOUR models
Mechanisms
Refinement of the suspension and braking system
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2591299
yeah i saw one of these on the road a while ago, and it threw me. didnt know it was a skyline till i saw the badge. looks more like the new maxima or something.
what engines do these have? turbo? i know i could google it, but meh.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2604721
ok, i cracked and googled, lol.
3.5L DOHC V6 NA. meh. i dont really like it. very family/maxima. how can they call this a skyline????
VQ35DE (NEO) type V 6 cylinder DOHC with an X toroid CVT 8 speed transmission.
It's more than worthy of the skyline name and is totally different to a maxima.
I parked mine next to a maxima the other day and they look totally different.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606849
id get the coupe - but its similar to the 350z i reckon.....bah just slap on a turbo when modding it - works well either way....
Edit - ok maybe interior is not that much like the 350z - i dunno...gives me the impression that one of them was trying to copy the other....
Edited by emsta2003
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606996
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
