  • Replies 245
You mean kinda like this one??? Although this one has also had the front converted to that of a 34 :thumbsup:
Holy snapping ducksh1t batman!!!! - does anyone have any more info on that thing?
gettin back on track for a sec..
been givin it alot of thought with Wildcat n we came up with a few good ideas .....
Xmas treasure hunt style cruise :)
Prezzies n all woohoooooo!!!!!
Whats everyone reackon??? ... give us ya ideas so we have some time to make this an awesome cruise :(
Ohhhh n Kylie i got a hacksaw if ya need a hand hehehee :)
Lee and I came up with some ideas last night like
1) Card Run -At every stop, ppl get to (randomly) choose a playing card, at the end stop who ever has the best hand wins and gets pressies
2) An Amazing Race style cruise...first one to get all the clues right and make it to the final destination also wins pressies
3) Treasure Hunt Cruise - i think lee named that the Stagea Santa Cruise or something!
4) A normal map cruise
Obviously there would be plenty of ppl out there with ideas so throw us some ideas..make sure its south as this time around we are heading down that way!!!
Mitchy the amazing race one is clue based so its not like race to the end..its like get all the clues and ones you have the hope you end at the final destination with them all correct
Kylie never heard of a poker run is it the same?
yeah except you pay for another card. Usually $5 to raise funds for kids or whatever.. bikers usually do them :yes:
I like the card one... the clues one would have to be fairly obvious or mitchy would get left behind :ninja:
maybe we could do donations for cancer foundation...seens there is alot of that going around at the moment :)
im also not available the sunday 17th :) maybe we should decide if we want a december cruise or an early new year cruise???
jan is way better esp for the late xmas shoppers like myself...
treasure hunt sounds like a good idea...organisers will be bored stiff tho coz obviously they wont be participating.
card game ...sounds like poker...maybe make it interesting an play drive by strip poker...looser drives home nekkid ..haha
amazing race <<kinda against this idea..i agree it is based on clues..but some may get overly excited and try outrun other participants...i kinda see a lot of speeding tickets with this one
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
