OK!
So i'm ready to change my dump pipes
i have got myself a set of trust front/extension, but just the pipes only!
i'm looking bolts, gaskets etc etc.
what do i need to go out and buy?
cheers
The trust Greddy Dump pipes have locating type lugs on them, and depending what Turbos you are bolting them to these may need to be removed...mine did.
You'll also need a box of Bandaids for all the scraped Knuckles you'll get :)
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
