Hello All.
I have just ordered a 97 Stagea through Prestige Motorsport. Check it out on http://www.prestigemotorsport.com.au/modul...hp?StockID=4102
First plan is to drop the suspension a couple of inches, install a better stereo and then work on a few minor mods to the engine (intake and exhaust mainly).
I will have to catch up with those of you in Perth once the car arrives - due in December.
https://www.sau.com.au/forums/topic/139211-new-member/
Nice.... dayz bodykit with the optional Momo steering wheel ! mmmmmmmmm
Good luck with it all.
Suspension - look at the Group Buy thru Sydneykid. Bilstein shocks, Whiteline springs and swaybars.
With the exhaust, dont settle for cat-back, definately go turboback, 3inch.
Now the wait begins, hey. hehehehe
https://www.sau.com.au/forums/topic/139211-new-member/#findComment-2593241
Thanks guys.
I have been thinking about buying one for a while but couldnt be bothered with the whole changing cars trouble. When i got the update from Prestige with this wagon i jumped at it and bought it. Yes - the wait is a killer - only another 6 weeks - i hope. I have already read up about the group buy and am keen for the bilsteins and lowered springs then i will follow up with the sway bars etc.
I was going to import an evo7 but the wife was not as keen so when i said i am buying a family( 180kw! ) wagon of for less than half the price she was blown away. Anyway, at least that leaves some cash for mods.
https://www.sau.com.au/forums/topic/139211-new-member/#findComment-2596509
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
