Just put the lightweight shockproof redline oil into my gearbox today. Now I can easily change to 2nd gear when the car is cold. But, I feel crunches for 1st, 2nd and 3rd gear, even when the car is warm. I think that it's worser than before. The crunches is absolutly noticeable.
The old oil that drain out from the gearbox is something like auto transmission oil.
What happen to my gearbox that react with the redline oil like this? any ideas?
:shake:
https://www.sau.com.au/forums/topic/13926-i-feel-worser-with-redline-oil-why/
Give it an easy 1000km+ before you make up your final decision on the Redline Oil.
For the first few days I was like "mannn i paid $100 for this stuff".... but now 5000+ km on and its the best $100 I've spent on my car.
yeah give it a good 1000km or so.
i used to get crunches into 2nd, they went away after about a week of driving after putting in lightweight shockproof. then about a month later, shifts became nice and easy, i have a short shift kit and shifts used to be really tight, too tight, now its just nice.
Yes, maybe the clutch adjustment problem. Everytime when I change gears, I will depress the clutch pedal all the way down. But, I only need to release it a little bit and the clutch start to engage.(car start to move)
And I found that the clutch fluid level is in the middle of the "max" and "min" mark. Should I put more clutch fluid in it? And what sort of fluid should I use to top up? Can it mix with different brands?
Or should I change all the fluid? if so, how to do it?
Thanks!
What I tend to do as a standard to my car is that " If the item and or fliud is unknown best to change it with a known item."
This way I am able to control what goes into the car and not to worry anymore. In the case of clutch and brake fliud fresh is best naturally. If the fluid has been sitting around in the garage or in a car for a few years they tend to absorb water leading to corrosion in the lines down the track.
MoonButt
  • 1 month later...
Hmm, perhaps you should have used Redline MTL or MT90. They are the ones that were designed from the start to give you better shifting, not Shockproof (even tho it does a good job too).
If it was ATF, it does give good shifting being really a hell thin viscocity, but it ****s up your box pretty badly after a while, because ATF does not contain the proper extreme additive protection that gears require.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
