  • Replies 41
i believe normal r34s run H1s but for some reason mine run H3s....wats the issue here and do u no which i should use?
dude doenst really matter what bulb your car has just change it with the one thats in it
if it runs a H3 bulb change it to a H3 kit
you might have H3's as you might have the halogen headlight assemblies? Early on in the R34 compliance stage, the entire headlight assembly was being changed. Now they just modify the Xenon assemblies.
either way, unless i see some pics... R34 owners at least will prob be quite disappointed with any HID changeover.
You really need the OEM parts... but again, waiting on pics.
man thats bs.....im so angry that they pulled em out far out. where can i get a set of the original xenons?
i hope i can count on u gohan to point me in the right direction with what kind of xenons i should get lol. i dont realli know why but i feel like H3s aint as good as the original h1s.....correct me if im wrong
you're wrong.
there is no different between the globe types, and what kind of light they produce.
if you had H3 in the left, and H1 in the right, you wouldnt notice a difference.
you're wrong.
can u explain why they converted my h1s into h3s?
s15 run projector headlights, yes?
projectors have a nice clean cut off, and are best suited to Xenon bulbs. Hence 99% of factory Xenon headlights are put in projectors.
R34's have reflector assemblies. Do your headlights have the word 'Xenon' embossed anywhere?
When was your car complianced?
original globes wouldn't even be H1's. They would be like D2R Xenon bulbs. Originals weren't even halogen's.
nismos15, could you take a pice of your headlights pointing at a garage door or wall?
do you have any pics of this kit in a car without projector headlights?
i have the word Xenon right under my buld....my car was done back in feb
posted some pics up of my headlights here
http://www.skylinesaustralia.com/forums/in...howtopic=140889
Edited by anDru
i have seen the 2 bulbs together there is not much difference just that the part that the H1 bulb sits on is different to H3 one to fit different headlights but the light looks the same
im not to sure with the r34 headlights but if you like a h3 i can get one for you no probs
hey which ones do you have your s15? as gohan said the projectors have a nice clean cutoff, does this still apply with the xenons?
ie the light pattern on the road looks the same as normal globes, besides being brighter/whiter/etc of course?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
