Can any one help me i have been told that the vg30 turbo off the single turbo 300zx will fit on to the RB25 det neo and that its a good upgrade for a bit more power. Has any one done this or no any one that has and are thay happy with it.
Thanks Ryan
https://www.sau.com.au/forums/topic/139387-vg30-turbo/
I'd say that getting a Sliding Performance high-flow or a Sydneykid group buy GCG high-flow would be a better choice.
But as far as I know , they are slightly larger than the RB25 ones and bolt up with minimal, if any modifications.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597608
Thanks Ryan
One answer... No. :mad:
If you run the turbo off a 300zx you will have to change dump pipes etc.
If you were to run a turbo off the later model VG30DET's from the Leopars/Cima's etc then you don't have to change anything; but the turbo's are not matched with 'performance' in mind. The run nothing more than an RB20DET turbo's guts with larger turbine and comp housings to make it lazier so that it gives smooth progressive power for their cruisers..
The by far best T3 Nissan turbo is the R34 GTT Turbo, it runs the larger OP6 turbine housing as the VG30DET turbo does but a nice chunky compressor wheel. Not a piss fart RB20det compressor wheel like the VG30det turbo does.
And no... its not worth the upgrade for 10rwkw. :mellow:
Highflow the turbo; GCG if you want maximum response with good power, the slide turbo if you want to save a few $$ or see if you can track down a nice little HKS GT2530.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-2597812
  • 1 year later...
Sorry to resurrect an old thread, though I am in the throws of purchasing an R34Gtt turbo to replace the VG30 turbo currently on my RB20DET.
I am trying to get rid of some of the lag.
Will this help given that the R34Gtt shares the same exhaust housing as the VQ30?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3457832
If i'm not wrong the VQ30 has a bigger exhaust housing to the R34 GTT turbo
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458086
I'm not sure - I guess that's what I am trying to figure out (as I want less lag and I am told that a larger exhaust housing = more lag). Cubes (above) has written that they are the same and Manwhore (on another thread) agrees.
Edited by Birth
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458165
VG30 and R34 GTT turbine housings are the same.
The R34 turbo has a slightly larger compressor wheel that is possibly lighter due to the material it is made out of.
It will punch harder when it comes on as a result.
The R33 S2 turbo really is the best pick out of the std turbo's for the rb20.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3458588
Just a question, turbine housing and exhaust housing are the same thing or different? I'm sure the VG30 single turbo is definitely bigger than the R34 turbo in certain ways, thus giving me more power as proven on dyno. Have a friend with a high flow R34GTT turbo put on dyno and my hi flow VG30 turbo on dyno, i have about 10 rwkw more. Not much of a difference though i feel.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3464337
ok, I have bought an R34 turbo with the OP6 exhaust housing as it is a bargin. I am looking at acquiring a new exhaust housing via swap or buy - what should I be looking for, a. one from an R33 turbo because that is what everyone is telling me to buy because the ex housing is smaller than the OP6 or an RB20 housing because that is even smaller than the R33 housing, but the R34 compressor will off-set that with better flow?
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3465451
  • 4 weeks later...
To finish this converstation off - I have installed my R34 GTT turbo. The swap itself was obviously simple. I think that the R34 turbo is better - there is more boost early on and the car feels alot more drivable, though I do miss the surge of power that came on with the VG30. Don't let me be a sook though, if you have an RB20 and you are looking for a cheap upgrade neither is a bad solution (the VG30 is in my opinion certainly better than the RB20 turbo), though I think that the R34 is the way to go.
https://www.sau.com.au/forums/topic/139387-vg30-turbo/#findComment-3509663
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
