HEYY... i havent been on in a while, i have been really depressed (my girl needs my love, she is so lonely ATM.. im gonna buy her some presents when she is cleared!)
the car still has 2 weeks before she goes in....
DAM wait!
i have decided to change the obvios but leave some parts on as to give them some easy things to get :dry:
:sleep:
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2661140
  • Replies 97
i know helping out a fellow club member or interested buyer here on the forums for stock parts is a nice thing to do and a good idea, but make sure u got triples of them parts and teh money to pay for labour just in case u get defected and u need old shit in and new shit out and vice versa. 2 cars would be ideal but not all of us have xxxx amount of cash to buy 2 of the same car and keep 1 stock.... and thats just for bolt on mods.
Edited by SAZilla
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2661199
DAM wait!
:sleep:
i think thats a good idea not changing every thing and you never know they might pass some of those things you didnt change
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2661535
yeah, i think its a definate that they will gimmie a fresh defect list even if the car was completly returned to stock.
so... im gonna let them tell me what to do.
last thing i wanna do is pull suspension, diff ect. out for no reason.
anywayz. i cannot believe how much my car is a part of my life :D
im lost.. IM IN COON COUNTRY!!!!! :):/:P
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2663215
  • 3 weeks later...
hey guys! just took my car through regency.. :)
The List:
- eye level rear tail light to work
- all emission controls to be re-installed (supply report stating all plum,bing correct)
- fit dry cell type battery or vent to atmosphere
- refit all child restraint systems
- remove flare and despose correctly
- pedals
- front and rear suspension to be raised to 360mm
- repair missing/brocken exhaust manifold studs
- re-instate rear steering control sytems (hicas) supply report stating operation ok
- re-instate abs control function. (doesent have abs.. IDIOT) supply report stating operation ok
ALL REPORTS TO BE FROM REPUTABLE DEALER QAUILIFIED MECH.
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2706236
Whats the All reports to be from reputable dealer qualified Mech.. Sounds like engrish. :domokun:
Did you question the abs control function?
They really must have gone over it with a fine tooth comb to pick up the exh. manifold stud UNLESS its can be easily heard.
So whats this about the reports etc? Does that mean a mechanic can supply a report and they dont check *doubt* or?
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2706328
yeah, i told him it doesent have abs and he looked at me (its quite obvious) i think he was referring to the sensor i have questioned to you guys before located at the front nose of the diff.
well my father is a mechaninc and thinks he knows people that could state it in reports. also i know a few people.
he told me i need a charcoal cannister fitted, i said yes, its fitted it disposes of fuel vapors and then showed him were it was and the lines, he still said i needed it checked.
there is no leaks from the manifold, have organised a hi flow from slide for her, was planning on doing the studs then, but i think ill have to doubble handle as a hi flow would screw with emissions even with stock ecu.
he also questioned the boost solionoid i explained it to him, but then thaught it was best for someone to check it out.
yeah, i think as long as i have a report its ok.. i hope i find a decent mech and it easy and cheap.
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2706366
A highflow won't screw with emissions as they don't test them at wot, only idle, cruise etc when its off boost.
If anything the only thing it will screw with is making the car louder.
But really.. what are these amature knob heads inspecting cars for when they have NFI what they are on about...
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2706457
I can't see why you need things like the Hicas to be re-fitted. Did your car have it? As long as the suspension is properly aligned it's perfectly safe & just like 99.9% of all other cars out there that have no rear steering system. What a joke.
As far as the boot wing goes I think I may know what's wrong. I fixed my own, it turned out to be a current limiting resistor that was on the +ve input just near the where the wires feed in. It gets moisture in through the seal & corrodes the resistor till it no longer works. I pulled it open using a hair dryer to help separate it (though a heat gun would have been better) changed the resistor & sealed it back up again with clear silicon as well as the wire seal to stop it leaking again. Wouldn't know I'd touched it.
Could probably give you a hand with yours if you like, there's bugger all to them. It's a bit fiddley but worth the effort.
Edited by JazzaR33
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2707531
I believe there were some they didn't come with hicas as there is a powersteer pump available without hicas.
Most likely the n/a base model.
I'm probably wrong though as I don't know for sure.. Just something I vaguely remember.
this is correct
sux to hear how much they reemed you jase! g/l with getting it all fixed and fingers crossed it doesn't cost you your left testicle!
https://www.sau.com.au/forums/topic/139443-defected/page/4/#findComment-2707701
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
