Upgrading my kit as it's a bit more piggy now so my old kit is off. It's a Type M kit off a R32. The Type M is additional factory extra's which consisted of a different front bar, sideskirts and rear pods.
Front Bar - $200
Skirts - $150
Rear bumper - $150
Pods - $50
From The Rear (Yes I know the back tyres bald, sunday daytime industrial dorifuto fun minutes before this pic)
All this stuff is in excellent condition and have had a bit of interest but no one has come up with the money yet. It's a nice looking kit, and would suite a 32 that's slammed on it's ass, although is good for drifting/track.
I'm located in Perth, WA so we can work out shipping interstate if required. Maybe 50/50 in costs?
0431 059 615 - PM - [email protected]
Thanks, Jason
https://www.sau.com.au/forums/topic/139573-fs-white-r32-type-m-kit/
Hi guys,
If you want to have stuff couriered you could try calling the Fastway Perth office yourself to arrange a pick up from JZN32's place to your door.
The number is 08 9353 6401. They quoted be around $110 for the front bar to Sydney wrapped in bubble wrap.
See how you go - it would mean less of a hassle for JZN32 and maybe get your your parts quicker.
Give me a price for the rear pods and side skirts. Including postage to sydney 2222. Please get back to me asap as my car is sprayed as we speak and i have still yet to get my hands on the skirts and the rear pods.
Ur asking, 200 for just parts. So im assuming roughly 150ish for postage.
Let me know exact and you got a deal.
However, i dont know how you go about buying stuff through this site.
Regards,
Daniel
email me at [email protected]
Hey guys, sorry about the delay. I got roughly quoted today for everyone enquiring. Not too show how they sound but here they are:
legend01 - Skirts/Rear Pods = $62.18
chinkeboi - Skirts = $97.50
Richo - Rear Bar = $117.52
RB20JT - Side Skirts/Rear Pods = $132.31
DJRIFT - Front Bar = $192.15
Feel free to check for youself using the Courier of your choice.
Full kit is for sale still, has to go soon, I got a new kit and this one will be taking up bulk space in the garage.
Jason :)
im very interested.
would u consider a straight 300 including postage?
cheers
Jason :)
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
