Hi Guys,
I have recently been having problems with my 32 gts-t. Basically under hard/full acceleration the car was flat spotting where it felt as though petrol was not getting into the engine properly around 4 - 5.5 thousand rpm.
First my mechanic tried a fuel additive which seemed to fix it but then it slowly returned. Then got the injectors ultrasonic cleaned. Again, seemed to fix it despite the fact that when i got it back the car had serious problems starting which it still does. 2 out of 3 times i hold it on start while its turning over and over and doesn’t come to life. After a second try it splutters into life. Now the flat spot has returned again.
It has cost $300 with additive and injector cleaning so far and back where i started. Also, it also does not idle well, specifically when pulling up to lights and selecting neutral while rolling to a stop the revs nearly drop to 0-100rpm. I stop and it comes back up, goes down, up.....
I have a feeling from what I have read on these forums that the problem may be related to the AAC valve but I would appreciate anyone who could offer any advice.
Thank you in advance!
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/
chked ur fuel pump?
Yeah that was one of the next things I felt could quite likely be a cause of the problem. But I was wondering if the AAC valve is (and im not sure if this is so) causing the idle issue could that have any relation to the flat spot?
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2603706
You haven't stated if the engine has been modded in any way. Info like that is often useful in diasgnosing these sorts of problems.
Idle "hunting" is likely the AAC valve - it's the little cylinder attached to the back of the plenum chamber.
The flat-spot is totally unrelated to the AAC valve. It is likely the ECU is detecting "knock", which may be caused by a dying fuel pump. Get the car onto a dyno, with an AFR meter and a fuel pressure gauge.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2603857
AFR = Air Fuel Ratio.
There isn't a meter for this in the car.
The car monitors Air flow = AFM (Air flow meter)
and from this and other factors (tps etc) determines how much fuel to put into each cylinder at various revs/load etc.
The car also has a o2 sensor which tells the car essentially if the car is running rich or lean.
If you want a proper AFR you'll need to get a wide band AF gauge and probe. Very good tuning tool, lets you know exactly whats going on with your AFR's.
You know when you see people getting their car tuned on a Dyno, and they tuner's got a probe sticking in their exhaust? This is what that is.
Sounds like your problem is fuel issues, either too much or too little.
Generally the more mods you do to a skyline the richer they run. Richer=safer (away from detonation) but also means retarded as far as power use goes, and fuel economy goes down.
It could also be fuel starvation= Ie, dying fuel pump, blocked fuel filter etc.
This is the most dangerous of all senarios, if this is the case, get it fixed soon.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2605760
Thanks for the replies.
It's all very confusing. Im a bit worried now, I will have to minimise my use of the car from now on cause I am really busy with uni/wrk so cant get it looked at atm. The only day I have to use it is wednesdays, every other day i can get lifts/use another car or p/transport.
At least I know a few things it could be know. I hope i can find out for sure what the problem is.
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2607780
Just to add to that,
When I just drive the car normally (as in not rev beyond 3,500rpm) it is 100% fine and drives smoothly and without problem, other than the issue of getting it started... So this wednesday and next I assume that it wont be doing any damage driving like this??
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2607825
Guest tosboost2
ok to start i know on this forum that this guy says do this, and another guy says do that. so i dont care if u listen to what i have to say
but anyways i had the same problem with my 32.
i spent 600-700 bux diagnosing the problem and changing things, taking the car places etc.
it ended up being my afm was dead, so i got a new one, and the seal around my blow off valve was busted, i dunno how that made much difference but i fixed that, i still have a few problems but only when the cars cold, which is the cold start valve. and seeing as i cant find another one ill have the problem for a while.
find someone else with the same afm as you and just swap them over and see if that helps :laugh:
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2621547
find someone else with the same afm as you and just swap them over and see if that helps :)
Thanks for your help, my mate has a 32 gts-t like me, so I can try that then and ill put in a new petrol filter if that doesnt work and see...
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2622517
  • 3 weeks later...
Well for those who are interested... PROBLEM SOLVED
After being introduced to a friend of a friend, we got talking, and I found out he owns an r32 gts-t also, and is a mechanic!! He had rebuilt his rb20det and knew a lot about them.
Took my car to him and he discovered a pipe connected to the fuel pressure regulator was split in 2 places and barely hanging on. Replaced that and he raised the idle and it was fine, revvvvs out beautifully and sits perfect at 800pm at idle and doesn’t fluctuate.... all this fixed for next to nothing, meaning the $300 spent to date was wasted... at least its fixed !!!!! :pirate::):yes:
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2671185
which "pipe"
can you put up a pic of an engine bay and point to it?
cheers,
Warren
PS did it also help with the starting issue?
Yeah its pissing down outside now, but next available chance i will take and post pic, and yes it had serious issues starting sometimes, others it would be fine, but more often than not id have to try 2 or 3 times... all good now :P
https://www.sau.com.au/forums/topic/139666-rb20det-dilema/#findComment-2671595
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
