Hi,
I've got an R33 4door completely stock standard. I recently had the front brake pads replaced with Bendix and everything worked fine for about a week.
After that the brakes were different from drive to drive ie. sometimes they'd require the lightest tap and they'd pull up, other times the brakes wouldn't work until you get to about 1/2 way down the pedal. The missus reckons at some point she went flying through a stop sign because she couldn't stop :D !!
At the moment, they've stopped changing from hour to hour and are left feeling really weak, like you have to get the pedal 3/4 of the way down until they start to work, then they pull up fairly well.
As far as I can see, there are no leaks, and the rotors and calipers are fine + before the new pads were put in everything was working honky dory. Any suggestions guys?
The other thing is, the r33 pads wouldn't fit my calipers, they were completely different, I found out that I have r32 calipers. Is this unusual for a '94 R33?
Cheers
Matt
https://www.sau.com.au/forums/topic/139783-brakes-spongy-help-me/
to check if pistons are working fine, push them back with your fingers if they are too hard that might be your problem, thats what my brake specialist told me, am having big dramas with my brakes squeeling but can't figure it out
does the car pull to one side when braking? that will rule out a binding or stuffed piston probably.
-check for leaking brake fluid at calipers, brake lines and master cylinder
-check for kinks in the brake lines
-bleed all 4 brakes, replace the brake fluid completly if you feel the need, also check that all the lines are tight and the bleed valves are closed properly.
if it is still having problems after bleeding all 4 brakes, and the pads are installed correctly and no massive run-out on the rotors, rotors are above minimum thickness etc. then it's probably going to be a rooted master cylinder.
(also, remember to follow correct bleeding procedure especially if you have ABS brakes).
air in the lines is the usual cause of spongy brakes, did the resoviour get run dry for any reason? did you crack the bleed valve by mistake? did you loosen any of the brake lines when removing the caliper?
Edited by MerlinTheHapyPig
had the same problem and that solved it!
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
