Nismo Veruspeed Oil Filters - Suit RB20/RB25/RB26/CA18
2 Available
Each Nismo Veruspeed oil filter offers 21% less pressure loss, 24% increase in filtration, 10% less flow resistance, and 37% increased life.
$45 each or both for $80
Will post anywhere in Australia at no extra cost
Edited by GTRGTR
https://www.sau.com.au/forums/topic/139792-sold/
mate, there is no comparison. if you care about your engine, these are worth every penny. and a good price too.
please dont try and rubbish this guys sale mate.
https://www.sau.com.au/forums/topic/139792-sold/#findComment-2611631
2 Available
Please clarify which car it's for. The picture you have posted is a Nismo filter which is not suitable for RB-series engines.
https://www.sau.com.au/forums/topic/139792-sold/#findComment-2614101
The filters Chris is selling are RB filters, he has just used the wrong picture to advertise them
johnnilicte: In future, refrain from making such comments in other peoples sale threads otherwise a warning will be issued.
https://www.sau.com.au/forums/topic/139792-sold/#findComment-2614370
ive got a oil cooler with relocater. would this suite? i was told i need one size bigger than the stock ones
Thats interesting first time I have heard that...but then again...I just got my cooler fitted too.
So what size are they then?????? ;)
https://www.sau.com.au/forums/topic/139792-sold/#findComment-2615289
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
