  • Replies 208
Dunno 4Dirty2, im guessin everyone could put a couple of dollars together, how much were you thinking?
Heard from Hot4s and he is willing to come out and take a group shot for the magazine but will still need someone for shots of our own.
Yeah i think people wouldn't mind as long as it wasn't at all expensive.
Obviously it would only be for those in the main photoshoot as some people may just be coming for a looksee...or to take their own photos...
It'd be cool to get some SAU 'lines in a mag :)
i dunno about 5$ or 10$ an they suply the cd if 10$ other wise bring ya own or sumthin like that
he hasnt asked for anymoney but i just figured it would b nice as his stuff ant cheap an the more money he gets for this the better stuff he can get for other shoots an maybe get a job sum where he can help us in return in the future
pics were taken at the main shopping centre
Edited by 4dirty2
YES
what are the significanse of the cars in your sig 4dirty2
just wondering if you would consider running a mini sig with maybee only the skylines ?
other cars can be added i just personally think 850 pixel wide is a little large... thoughts??
Edited by Madaz
Its a damn sig.. lets not get fussy over it.. althought 850 pixel is rather large.. possible photoshop resize?
lol use say dont get fussy yet agree 850 is rather larger :wave: bit of double dutch
gts33t - You finally get something from Hot4s, what did they say? Are you going to be in the SCS? I would like to go for the photo shot and see other cars, if there is still enough room, but I don't know what time the show finish. Anyway, just another suggestion for you, if you can get those guys from the magazine to come, you may also like to put your car or someone's car to be feature. That's how I had the photo shot from Hot4s with the other group before, it featured 3-4 pages in the magazine for the whole group, looks very good and I remember the group photo has taken 2 full pages in the book already. :wave:
Just likemore skylines the merrier, more photgraphers the better i say, someones gonna get a better picture than someone else, i think everyone can make a donation when getting a copy of the cd from your mate 4Dirty2.
As for Hot4s i dunno if he will be at SCS but he will come take some pics of the big group.
Will send out PMs this week.
mr_rbman if you know this guy you can ask him but i dont know who he is.
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
