You guys dont play fair haha.
That'll look sweet on a White GTR. Cant wait to see some Pics
KINGY: If your In town some time this week (afternoon) I can snap a few quick shots for you
Edited by 89CAL
haha yeah i guess goin to work on weekend night shifts n all sorts of dumb hours has its advantages..
The car looks pretty good with the new tyres n brakes im very happy with how its has turned out..
Im headed back out to work on wed morning cal but yeah i'd love for you to take a few pics some time when we get a chance :thumbsup:
I like it. Looks like it needs a wash though :P
I'm getting my car on the dyno monday. It seems to have a small issue with the turbo not spooling quick enough. It's also pushing out more boost then set on the boost controller. We shall see. Gave it a oil change on the weekend. Wow.
