If mine dies I'll have a hard time deciding wether to switch or not. Buying a new PowerFC is easy. Plug it in, load my tune and away i go. But the added features of the Vipec are worth retuning.
Decision I hope I wont have to make for quite a while
Nah I didnt end up going, will sort out these boost issues and go next time KSOS and work dont line up
Next 1 is on the 20th Cal and im home for it. Pretty sure you are on the same roster to me?
Order the bushes and do it yourself I would not pay anyone to do anything in Mackay bunch of useless rip off merchants, I prefer to buy the tools I need and do it myself hate paying people to do shit.
I would have to find some sort of DIY guide because i'm in no way confident with something like this, but yeah i know what you mean!
If you don't want to do it yourself or take it to a shop, go and see Leon Minic, he'll do it for you, better than any shop and most likely half the price.
He's got quite a good set up too. He's one of the guys that runs the drift club.
Got any contact details mate and where's he from?
Press = hammer + socket lol
true, im going to have a chat to one of the boys from the workshop at my work and see if they have a press if not i can get a hand to do it DIY or talk to that Leon bloke and hopefully he has a press/can fix it for me cheap
