It's not far off. Waiting on a silicon hose for the oil drain and just have to finish off the head drain hose
Few little things then have to put the turbo and manifold on the old engine before it comes out to workout the wastegate placement and dump pipe but that shouldnt be a big deal :)
Who has got tyres fitted to wheels before (with you supplying the tyres)?
Ordered some new rears for my car today and will need someone to fit and balance them next week
Where do I got? Thinking Paget discount tyres or whatever there called might be the go but not 100% sure
Yep his whole garage is now a tyre shop/fitting shop haha it's hillarious.
Got my new gearbox clutch and flywheel fitted yesterday, car drives great. Clutch is so much lighter compared to the old HD exedy. It's making a little bit of a grind/rubbing sound when i engage it though, could just be wearing in but i'm getting leon to check over it again today and go from there. Happy with the results though!
Ok so i took the car back to Leon, he had a drive and he thinks it's the copper mix clutch. It makes a bit of a rubbing sound when the clutch is in changing gears. Just trying to find something on the internet with someone else having the same experience with this clutch
Pretty sure it's a pull type Cal. The noise appears when the clutch is fully engaged and changing gears. When the clutch is held in for about 3 seconds or more the noise stops. Yes there is a brand new throw out bearing in the car too. A couple of people i've spoken to think it's part of the wear in stage of a clutch, and the noise should dissapear after 500-1000km. I don't think the noise has anything to do with something not being installed correctly because everything is very smooth and no problems at all.
Yeah it could be just wear in. If your putting the clutch in and the noise disappears in 3 secs or so then whatever it is, is spinning with the gearbox so clutch plate would be
Email or call exedy and ask them if its worrying you
that's what Coz said from Conceptz. he said give it 500 miles then contact him again. I also asked him to contact the supplier for me, he's usually very helpful so i'll leave it for him to do for me. Is it possible the system wasn't bled correctly or something? there's brand new clutch fluid in there. I'm just trying to account for everything and narrow down to what the issue could be. Fingers crossed it's not a faulty clutch, Coz has never heard of this sound coming from the southbend clutch/flywheel setup. I guess time will tell!
This Power FC thing is doing my head in. My new one came the other day and I had time today to play around with it. It has the exact same issue. I'm hoping at least since I bought this new I can get some support from Apexi this time. I've tried just about everything I can think of now. Have emailed FC-Datalogit as well hoping that one of thier users has encountered the same issue
I might be heading for a Link at this rate, I'm not prepared to put up with the issue it has, as its annoying enough with the setup I have now, the lack of timing is gonna be worse with a bigger turbo and bigger cams.
Have yet another gauge to fit in my car somewhere now. Got my oil pressure gauge today. The sensor also doesnt fit in the block, both 1/8 threads but it looks like the sensor is NPT and the Block is BSPT. Went to pirtek for an adapter, and he couldnt find one and said just tap it out or put a spanner on it.... lol
finally after calling literally 9 different florists i've managed to get some ordered and delivered today.. let's just hope it actually gets to my mrs work before she leaves. shouldn't of left it til the last day though lol..
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
