Link has been ordered. Ended up getting it from Garage 7 along with a 4 bar map sensor, IAT sensor, expansion harness and boost solenoid for nearly $500 cheaper then what I was quoted from another dealer. cant complain with that :)
Haha I don't pay anyone to do anything, you should know that by now, but yeah still waiting of a few things so when it all gets here ill get stuck into it.
I didn't know if you'd leave hardcore offroad accessorising to a professional 4x4 fitter or not haha, so what exactly are you doing to it and did you end up buying anything through my work?
At the end of the day its all nuts and bolts I fit shit for a living :) . Never got anything through opposite lock, I ended up getting Custom Road Armour Bullbar from the USA expensive but tuff cost me $3K and I got 16" TRD Rims which look pretty awesome with BF Goodrich M/T KM2's 305/70 R16.
529667_10151463011148485_1794537908_n.jp
any one have any recommendations for getting my gearbox rebuilt in mackay? need my gear box rebuilt, fly wheel machined, new clutch put in and the rear main replaced. anyone know of someone that can do it cheap and reliably?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
