power cruise in September sounds good.. Hopefully my car won't be too far off maybe take it down to Bris in May for a tune, see how we go.. Need to pay the mechanic a few more beers haha.. ;)
Millions of dollars is more preferable :woot:
  • Like 1
I'm sure most of you have driven paradise st of late.... Wht a joke the upgraded road there is already started to fall apart ...... All the wet couldn't be doing it good but surely it has to have something to do with the quality of work carried out as well ?? Then what would I know I'm a boilermaker by trade lol
Mackay Regional Council have a tendency to do roadwork's in the wet season... dumb f**ks instead on hooking in on the winter months and getting it done properly. They need to asphalt everything once instead on shitty bitumen repairs 10 times over.
yeah they love doing half-arsed roadworks then scratch their head when the wet season comes wondering why the road doesn't hold together for longer than a week without giant crater-like potholes appearing.. always happened in Mackay lol. Amazing how different the roads are in Townsville compared to here..
Yeah cheers mate ..... Went and got a wheel balance done haha what a drama that turned out to be as it had a lock nut on each rim which I couldn't find the key nut for so me assuming that any wheel and tyre joint would have a grip socket to remove them went down to only find out they didn't and were not willing to remove them with a ordinary socket which I have done tons of time .... So back home I go and 10 minutes later the lock nuts are off haha should have done it myself first time around ! Anyways turns out each wheel was out between 10 - 30 grams lol feels heaps better now !
kool kool. well ill send ya a msg when im heading home and ill chuck em in the back of the ute and head round. ill bring rotors and rear calipers if you want. front sitting on there so they dont leak out.
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
