More questions. I started collecting the required parts but need to clarify a couple more things from anyone who's done this:
1. Can I reuse my original auto gearbox mount and cross member with the manual box? Both are R34.
2. Can I reuse my original auto shifter trim and just add a leather gaiter for the manual shifter? The cutout in the manual trim seems a bit bigger (see photos below), I'm just wanting to make sure that there's enough space for the shifter to move.
3. There's a fair bit of tar and grime inside the bellhousing of the manual gearbox that's going in and it's sitting pretty tight, what's the best way to clean that up?
Thanks guys!
Edited by V28VX37
To answer your questions after doing the conversion myself to my R34:
1) The Auto cross member and mount can be re-used
2) Yes, you can use your auto shifter trim. the shifter should not foul against it. I re-used mine. I bought a new leather gear boot and stapled velcro to the edges. Then I stuck 3m adhesive velcro to the underside of the shifter trim so the shifter boot stuck onto the trim.
3) Yes, you should clean the inside of the bellhousing, as you don't want that stuff in between your clutch. I used a wire brush, water, plenty of degreaser. Alternatively, oven cleaner or JIF could help
Fantastic, thanks mate, that's brilliant info!!
Ok more questions... I've ordered a new inner rubber boot for the gear lever as it's torn. How do I remove the wider top part of the lever to get it on there? It seems like it's glued on or something.
Also, am I meant to have a white nylon bush on the bottom knob of the lever? Where can I get one of those in Melb?
Edited by V28VX37
that top bit unsrews, i got my.nylon bush from nissan, make sure u get a r34 one as r33 ones are bigger and very similar part number. i'll see if i can find the part number.
Thanks. I'm not being very successful in unscrewing the top part, it seems like there's some rubber mounting between it and the bottom part?
Just Jap lists the Nylon bush as 32861-H7301, can anyone confirm if that is correct for the R34?
Had the same issue 3 months ago, the top part WON'T come off, so stop trying!
The boot is installed from the top (where the shift knob screws on). This description is going to sound a little weird, so bear with me :-o Lubricate the small hole & the shaft With a lubricant (oil or water based, as long as its slippery). Guide the shaft into the small hole, OK, enough, the small hole of the boot WILL stretch over the widest part of the shaft without tearing. I had my doubt's, but it does go over easily with a good amount of lube.
Yes you need a bush on the bottom of the shifter. You could enquire with gktech.com if they have a solid brass bush for the R34's. Some people like the improved shift feel they provide, but I'd stay with the factory nylon.
  • Like 2
Ok that worked a treat, the new dust boot is now in place. For future reference the Nissan part number is 32862 (BOOT RUBBER C/L). About $10 + postage off eBay.
I also got the nylon bush from a local Nissan dealership, the part number is 32861-H7301 (BUSH CONTROL LE) - this is for R34, R33 is different. Just Jap also sell these: http://justjap.com/index.php/genuine-nissan-gear-shifter-lower-bush-nissan-s13-silvia-a31-cefiro-r31-r32-gts-and-gts-t-r33-gts-and-r34-gt-t-and-gt-r.html
One more question: How do you install the circlip that holds the upper plastic ring (and the gear lever) in place? Mine seems pretty loose but there's probably a trick to make it work.
So this part:
Looks like I'm missing another circlip/lock ring, see below, any idea where to get one in Melb/Aus?
These too are available from your local Nissan dealership, part number is 32204-V5004 (RING-SNAP).
That second ring looks like it could be a back up ring that would sit underneath the circlip, cant be too sure, as I didn't pay too much attention when I did mine. :unsure:
You need a pair of INSIDE circlip pliers, like these:
Straight will probably be the go. Just pop the shifter in, put it in third, squeeze the circlip & snap it into the groove. Where the gap sits doesn't matter too much, just make sure you put it in an easy spot to get access to it if you need to!
Mine was alittle loose in the groove, so don't stress. Maybe mine was missing the back up ring!!!
  • Like 1
Thanks 533 RYC!
The conversion is partially done but they've hit a snag with the hydraulics ... Does anyone know if R33 and R34 clutch master cylinders are interchangeable?
If not, is there an easy way to tell which one I've got (based on a photo)?
Cheers
What dramas are you having?
So you've got an R34 GTT gearbox?
Did you use all R34 hydraulic parts?
What are the sizes are the Master cylinder & slave cylinder?
I'm not sure if R33 & R34 parts are interchangeable, as R33 is push type & R34 is pull type.
Seeings as the R34 GTT is a pull type, when refitting the gearbox, it is VERY critical that the input shaft is not bashed around going through the pressure plate. Engagement of the release bearing to the pressure plate is also critical. If it didn't engage properly, this could give you dramas.
Check out this thread if you haven't already found it:
http://www.skylinesaustralia.com/forums/topic/268118-r34-gt-t-clutch-install-guide/
Pictures would be great!
Thanks mate, pics below!
Not sure about master and slave sizes but they're both OEM, just wanting to confirm that they're R34 GTT and not R33 GTS-T.
The workshop has installed and wired everything up but they're having trouble engaging the clutch and asked me whether the master cylinder is an R34 item.
We are using an R34 gearbox and all R34 parts except for an R33 tailshaft front half. Brand new pull type NPC clutch.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
