  • Replies 55
U taste ure oil????? 8O
thats a new one prolly good idea though but then again y not just remember when u changed it last.
Im using penrite pedigree 5w-30 i have heard that its good.
I think royal purple is a bit expensive and its excessive if u change oil every 5000 as long as u dont put kmart multigrade crap in.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/2/#findComment-249
Tranmission oil needs to be thin, an idea i'm about to try is to use the highesy grade automatic transmission fluid in my manual box..with some uniglide or the other stuff (can remember name). Suppose to make the box really smooth.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/2/#findComment-251
pppfftt. Kays are just figure, The idea is try and get the little dial to spin as quickly as possible.....hehehe
George.
Yeap pretty sure RP is 5W-50W...Going to check tomorra and tell him to put some aside.
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/2/#findComment-16327
and how exactly do you tell if your engine is "worn"?
I have over 100,000 kays...
the last 30,000 were done by me, so pretty gentle. Can't really know before that, but it seems to have been treated very well.
Should i change to a thicker oil anyway?
https://www.sau.com.au/forums/topic/14-oils-aint-oils/page/2/#findComment-16614
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
