Haha...Hey guys, I havent got to the interior yet. It will be last so it doesnt get all messed up when nothing works once everything else is back together LOL
I know for sure you can buy all the interior parts new, still in stock. Gotta love Nissan. I love how i can look up any little clip/bolt/sticker off FAST and give them the P/N and they can get it! I was so suprised to find the most basic things available then i just kept asking about little finicky things and they have rarely been unavailble. Infact i think only one thing was and that was a bracket that goes on the inner rear quarter panelling.
Anyway most of my interior was in pretty immaculate condition. Just looking to replace the main dash section (big bubble unfortunately), rear upper trim pieces, RH lower trim piece, hand brake and gear shift boots (i'll go with custom leather), hand brake grip. I had planned to get a set of Nismo or perhaps the HKS Kansai floor mats to freshen it up even more. All the upholstry etc will be steam cleaned before refitting also.
Anyway i just popped on to add some pics i may never have added of my freshened up A/C compressor and P/S pump. Im quite proud of these as i did them myself and even transferred stickers! Yes, i know im crazy but it just adds to the attention to detail/are you f#$%^&* serious factor. Thats what its all about for me.
Edited by Godzilla32
Hmm, well considering how much ive poured into it...Lets just say i'd want alot LOL
I think i will always keep it and hand it down. I just can't see myself ever getting rid of it after so much work and money.
What do you think it would be worth one day?
Theres no doubt that a dead stock, completely original from factory, never been touched example would fetch more, but thats not as much fun to drive :P
yeah i was thinking about buying a new handbrake too.
I bought a brand new r34 gtt one when I did the stagea manual conversion and it looks great (and not too pricey). wonder if they have r32 ones still in stock
/goes off to order one before either of you....
Damn you drunkan!
Before you order them could you please let me know what the damage is? Im after them aswel :P
Cheers Nick! Long time no see. Chris my mate with the white silvia has told me he's seen you.
Yeah I've seen him a few times around the traps, just missed him on Saturday night actually. Did he have an accident in the Sil???
Are you back in Vic any time soon or are you a converted banana bender now :worship:
Are you back in Vic any time soon or are you a converted banana bender now :)
Yeah had an accident in the silvia after we fitted a 2560r garrett, FMIC and wound up the boost to just under 1bar. Pity cuz it was going really well :D
I may be back one day in the future. I want to come back, but i have recently become a proud father! So im not sure what will happen in regards to my living arrangements. Just have to wait and see.
On another topic my parts arrived from Japan. I was able to then fit the new Cusco strut tops to the Apexi N1 dampers and fit them into the car. For the first time in about 18months i can no theoretically put the car back down on her wheels! I will need to bolt in the outer cv joints if i do plan to though, as without them it wont have anything holding the new wheel bearings together. They very quickly start to separate into halves and even if you do press them back into place 50% of the time they are pitted and are noisey. Something to watch out for!
I sent my sump off to get bead blasted back to new finish. It was pretty clean after a hard scrub, but me being me, i had to have it perfect! Once it returns i will consider fitting new front diff bearings to be sure its quiet and then i can fit my new Tomei sump baffle and bolt it back onto my new engine! :D
From there i can use my new Tomei metal head gasket to refit the cylinder head. The kit also came with metal manifold gaskets, throttle body gaskets, etc so they will be used along the way.
Im close to having enough cash for the Garrett turbos now, but ive heard Aaron Slide may be out of stock?!? Have to enquire.
That concludes the latest update.
Deren
Hey people, a few quick snaps of the cylinder head on the block. A little frustrated however, as i wasnt able to torque it down due to the fact i have misplaced the head bolt washers. I have a feeling i forgot to take them out of their homes before sending the head away. The oil helps them stick there even when removing the bolts themselves. So im going to buy some new ones monday and have them sent out to me ASAP.
Note: Oil return tapped into the rear of the cylinder head.
Deren
umm yeah, I have made the washer mistake too, nissan was expensive and they were quite a specific size and shape that were hard tofind (quite think)
probably a bit late to mention now, but if the old motor died of a spun beaering you should replace the cooler that sits behind the oil filter - particles get stuck in there real good, no matter how well you clean it out
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
