Ok i was aware of their heater hose sets as i have one of them lined up but i wasnt sure they had a complete set with every single little hose lol. If i do it i wanna replace every one of the vacuum and coolant ones. I reckon it'll be alot cheaper to buy lengths of straight tubing and just cut it to size.
I have got onto a Samco distributor that can supply me with a heater hose set and radiator hose set. They also have every other silicone hose known to man. All the hoses that i need to replicate are laid out and i think the soft silicone tube will make the bends. I'll keep you all posted with updates. Next step, as i think i already mentioned, will be picking up the throttle bodies. I'll try to get that done in the next couple of weeks :down:
Uni-coils. Yeah thats an idea if it comes to that. I think you mis-understood me. I am getting Samco radiator hoses in a proper kit that are made to fit like OEM. Aswell as a heater hose kit. The ones i will be making up will be just the 9.5mm coolant hoses that run across the front of the timing cover and there is one that runs around the right side rear corner of the cylinder head. I'll probably use the same stuff for the vacuum supply hoses for the brake and clutch boosters if it will look ok. The Samco products are quite well priced which i was pleased to find :)
Planning to pick up the rebuilt throttle bodies this week coming after work one day. This will hopefully be one of the last bigger spends that i will have to make on the engine. I have added some updated pics of the engine since properly fitting all the coolant and vacuum pipes to the turbo side of the engine. Its now complete minus the silicone tubing and the chrome plated twin turbo pipe and the one that feeds it off the rear turbo.
On another note who can tell me if the Wurth thread tape will hold up against the high temps seen on the o2 sensor adapter threads?? It melts instantly with a flame but they will only really be subjected to high temps not direct flame. Im worried about this so can someone help me out?
Deren
Edited by Godzilla32
Deren, without checking back through your posts, but did you end up painting those turbine housings? I like the finish on the heatshields too...looking mint.
Cheers
Brendan
(the other anal retentive car nut)
Hey Brendan, we are 2 of a kind it seems.
I couldnt afford to coat anything with heat proof finish unfortunately. As it is im about 1 million billion dollars over budget. No wait...whats a budget? Oh yes, that figure i once had in mind of spending.. Im trying not to leave anything out that i can't do later but within reason. This project has gone from a accident repair and nice paintjob to a fully blown ground up rebuild. If i don't draw a line on some areas i will never get it done on my wage.
Im currently working on my external oil return made up with genuine Earl's braided perform-o-flex hose, and swivel-seal fittings. Im also organising chrome plating of the inlet plenum and the twin turbo pipe.
Ive kept an eye on your Silv blog. I like what you have done, very tasteful :thumbsup:
Thanks mate, yeah i know its worth it :( Just hard to wait this long.
Tonight i picked up my rebuilt throttle bodies and had a good chat to Will at JHH. Nice guy.
I hope they provide me with a nice, smooth, low idle! Similar to how it was before i messed around with them.. lol
Hey Deren, I don't see any sealant around those.....going to put a little in just to be sure or does he think it will be ok? Not that I can really see the interface that needs sealant from this angle......
I've been trying to help a few other guys that are OCD and pulled their TBs off, then cleaned all the "gunk" out and now can't idle lower than 1500 :) No reports if they have resealed and had success yet.
Hey Geoff, No they have advised me that is a bad idea and wont be necessary. They are very finely machined so only about 1 thou clearance around them to prevent sticking throttle plates. Will at JHH actually advised me the idle may actually be too low initially and require extra bypass air or even to have to crack the throttle plates a tiny bit. Now wouldnt that be nice :D Would really make the $600 worth while. Considering i have spent well over a $1000 dollars on trying to fix these bastards now im hopeful its fixed! Shame i didnt know brand new ones from Nissan were available to me at $1000 bucks complete with linkage arms etc. RRP might be more though.
Ron, i have kept busy ;)
Originally I had them done at a place in Melbourne, but the business was going down and screwed me over. So i wouldnt reccomend them for the simple reason of...I just had them redone properly! Look for automotive engineering shops that do alot of machine work on late model jap engines and you will find some of them do a fair bit of throttle body work.
A few quick shots. Looks a bit of a mess at the moment, needs to have cables plugged in and tied away. Dirty finger marks cleaned off. Still, its coming together and looking pretty sweet. The end result will be one clean Rb26 unit! :w00t:
Some more pics of ancillaries fitted :) Its getting closer now!
Things still to do:
Have the plenum, twin turbo pipe and the feed from the rear turbo chrome plated
Purchase, assemble and fit the Earls external oil return
Purchase and fit all new Samco coolant hoses and vacuum tubing
Ultrasonic injector clean and flow check
Thanks mate, i was thinking the other day just since moving here to QLD the amount of cash ive poured into the GTR i could have easily bought a $30,000 sports car :domokun: It'll be one nice GTR but if there was no accident to spur me on to do this build i could have had 2 sports cars. My dream is to have an S15 as a daily car..
Deren
Wait until the GTR is fresh and handling well mate. The S15 dream will disappear pretty quickly, especially since they have spaghetti for gearbox parts in the 6 speed. So it would be a labour of {something....certainly not love} once you feel the urge for some extra go. I drove one once, and it was ok and they look alright but just so not a Skyline. It was a tighter fit than a GTR32 for me and I recall you aren't so little anymore :)
This is something special happening though. I remember how much you were into it before you started the massive build and I doubt I will ever see the day you get rid of this one, just as I plan to have the 33 forever, and plan to die in it when it all gets too much.
Have you thought about protection? I recently picked up a car bra for the 33 on ebay for about $120 second hand but almost unused. Sure thay look crap and wanky but after I get the paintjob I will want to have it and like the idea of being able to remove it for paint maintenance. Plus I see a number of the cars that P1 Supercar club that I have driven are protected by a thin film of tough plastic over the front panels which I was contemplating until the car bra popped up.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
