Started New Job Today
Guest INASNT
Started my new job at GE today!
***ing pain in the arse when i have to start at 9am and have to drive to Hawthorn. Saw i black r32 gts-t on the way to work on princess highway, looked like nackers 1 but it wasent him.
I got underground parking and as i though ***ing front spoiler rubbed all the way down the ramp.
Luckly i found another spot without a bad ramp.
Any1 else go down princess that time of day?
https://www.sau.com.au/forums/topic/14003-started-new-job-today/
yeah, well your ass must be hurting right about now denham! GE huh - Doesn't GE stand for Gay Emporium ?? :P
Hah, hawthorn.. 5 mins away.. Get outta my neighbourhood bytch! :)
ahhh... so much fun.. this thread is going to quickly degenerate now :)
Anyway, good luck!
(make sure you bring plenty of vasoline to work each day..that will stop the rubbing..hehe)
Guest INASNT
Originally posted by Ronin 09
inasnt, nice one. so when is the new turbo coming?
i seriously need another car to drive to work and back, farkin enoying drivin at 60-70km/h stop and starting through the heavy traffic.
Prediator
trust u to know a company named GE that has something to do with Gays. :shake:
Ambz
wtf work r u gonna do in dande?
hehe if by nackers u are refering to me... then as u said it wasnt me :P i can barely get up to come to work @ 1pm let alone that early.
good luck on the new job denham!
Thats the GE offices near the train line right? ahhhhh i know the place, was 5 mins from my old place :P traffic around that area is a biatch, especially the bridge to toorak!
Good luck with it all denham.... :)
PS- god help us all that denham is really an engineer... any wonder alot of power stations collapse..... lol jkn!
Prediator
Ambz
Man no shit, do what i did. Buy a clapped up 3 cylinder charade to get you to work. Man i get 600KMS to a tank, and it cost $25 to fill!!!
Then on your way to work, you can hit shopping trollys and those rebounding reflectors !. Makes that driv to work sooo much more funn... :shake:
Guest INASNT
Good luck with it all denham.... :P
Yep the office is right opposite swin uni.
U used to live around there? damn u must have alot of $$ to buy a place around here.
I found a nice short cut so i dont have to go through glenferrie road and i avoid all the trams and crap. Takes me 40 mins from noble park if i leave at around 8am.
I am with hydro electric (water powered turbines which looklike big turbos) powerstations so theres less that can go wrong! :shake: Well they wouldnt be paying me $37/hr if i didnt know what i was doing would they? :P
yeah, i gotta get myself another car i think.. skyline to work each day is too much wear.. $1500 for a cheap shit mobile is going to be worth it in the longer run.. even just for the fuel savings. I spend about $60 in petrol each week going to work and elsewhere :P
There is another building that they are in just off glennferrie rd i think...
Its only a 15 min walk from my old house (2-3kms) and back when i was at uni it could talke me up to 20 mins to drive lol. The traffic ate ass!!!! So i just walked after that :spank:
Yeah Den, use to live in Kew, kinda at the top of glenferrie :D
YUP, GE = General Electric
There are many GE business's world wide, i work for GE Capital Finance Australia.
There is GE Auto
GE Medical Systems
GE Plastics
GE Power Systems
hmmmm, there are many other australian ones, the GE business's in Australia are no-where near the size compared to US's!!
ive never heard of the location in Hawthorn, near swinburne, im wondering which one it is!!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
