Started New Job Today
Guest INASNT
Started my new job at GE today!
***ing pain in the arse when i have to start at 9am and have to drive to Hawthorn. Saw i black r32 gts-t on the way to work on princess highway, looked like nackers 1 but it wasent him.
I got underground parking and as i though ***ing front spoiler rubbed all the way down the ramp.
Luckly i found another spot without a bad ramp.
Any1 else go down princess that time of day?
https://www.sau.com.au/forums/topic/14003-started-new-job-today/
yeah, well your ass must be hurting right about now denham! GE huh - Doesn't GE stand for Gay Emporium ?? :P
Hah, hawthorn.. 5 mins away.. Get outta my neighbourhood bytch! :)
ahhh... so much fun.. this thread is going to quickly degenerate now :)
Anyway, good luck!
(make sure you bring plenty of vasoline to work each day..that will stop the rubbing..hehe)
Guest INASNT
Originally posted by Ronin 09
inasnt, nice one. so when is the new turbo coming?
i seriously need another car to drive to work and back, farkin enoying drivin at 60-70km/h stop and starting through the heavy traffic.
Prediator
trust u to know a company named GE that has something to do with Gays. :shake:
Ambz
wtf work r u gonna do in dande?
hehe if by nackers u are refering to me... then as u said it wasnt me :P i can barely get up to come to work @ 1pm let alone that early.
good luck on the new job denham!
Thats the GE offices near the train line right? ahhhhh i know the place, was 5 mins from my old place :P traffic around that area is a biatch, especially the bridge to toorak!
Good luck with it all denham.... :)
PS- god help us all that denham is really an engineer... any wonder alot of power stations collapse..... lol jkn!
Prediator
Ambz
Man no shit, do what i did. Buy a clapped up 3 cylinder charade to get you to work. Man i get 600KMS to a tank, and it cost $25 to fill!!!
Then on your way to work, you can hit shopping trollys and those rebounding reflectors !. Makes that driv to work sooo much more funn... :shake:
Guest INASNT
Good luck with it all denham.... :P
Yep the office is right opposite swin uni.
U used to live around there? damn u must have alot of $$ to buy a place around here.
I found a nice short cut so i dont have to go through glenferrie road and i avoid all the trams and crap. Takes me 40 mins from noble park if i leave at around 8am.
I am with hydro electric (water powered turbines which looklike big turbos) powerstations so theres less that can go wrong! :shake: Well they wouldnt be paying me $37/hr if i didnt know what i was doing would they? :P
yeah, i gotta get myself another car i think.. skyline to work each day is too much wear.. $1500 for a cheap shit mobile is going to be worth it in the longer run.. even just for the fuel savings. I spend about $60 in petrol each week going to work and elsewhere :P
There is another building that they are in just off glennferrie rd i think...
Its only a 15 min walk from my old house (2-3kms) and back when i was at uni it could talke me up to 20 mins to drive lol. The traffic ate ass!!!! So i just walked after that :spank:
Yeah Den, use to live in Kew, kinda at the top of glenferrie :D
YUP, GE = General Electric
There are many GE business's world wide, i work for GE Capital Finance Australia.
There is GE Auto
GE Medical Systems
GE Plastics
GE Power Systems
hmmmm, there are many other australian ones, the GE business's in Australia are no-where near the size compared to US's!!
ive never heard of the location in Hawthorn, near swinburne, im wondering which one it is!!
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
    • The detail level is about right for the money they charge for the full kit... AU$21.00 each issue, 110 issues for a total of $2,300 (I mentioned $2.2K in the first post when the exchange rate was better). $20/week is doable... 😐
    • If planning on joining us for the day(s) please indicate by filling in this form. https://forms.gle/Ma8Nn4DzYVA8uDHg7
    • You put the driver's seat on the wrong side! Incredible detail on all of this. It looks like you could learn a lot about the car just from assembling the kit.
