hi guys. just need some advice.. R33 GTS-T.. started to idle bad. up, down, up, down and black smoke coming from the exhaust. i was told most likely coils are on there last legs. sometimes car ok to run but then all of a sudden no power at all hit the peddle and just misfires bad. very jerky.....
replace coils???
steve
https://www.sau.com.au/forums/topic/140077-miss-fire-bad/
Does it do it more when the car is warm? under load? If so it probably is an ignition problem.
Check your plugs and gaps first mate, throw in some new ones gapped to 0.7 to see if it improves. Im having the same problem at the moment the new plugs have improved the car but its still missing at times so I just ordered a set of splitfire coils from nengun like 5 minuets ago.
https://www.sau.com.au/forums/topic/140077-miss-fire-bad/#findComment-2609390
Whilst you are re-gapping your spark plugs, check the coil packs for cracks and scortch marks!!!!
https://www.sau.com.au/forums/topic/140077-miss-fire-bad/#findComment-2610053
Could be the airflow metre as well I think? Sounds reminiscent of my AFM problems from my R32. Can you check the error codes on an R33?
With my r32 you would just be driving along and all of a sudden it'd cough and splutter and lose all power for about 10seconds, then she'd continue on like nothing happened. Whacked another afm in and it was fixed.
https://www.sau.com.au/forums/topic/140077-miss-fire-bad/#findComment-2611610
agree afm prob....
the black smoke n bad idle usually caused by afm ....
go to any of ur mates that have a late model r32 or a r33 swap it wif deres to see if dats da prob if not replace sparks with even .8 gapped running onli stock 7 psi n see if dats ok n then work your way up with coils... the more u move away from stock the more hassles u get if sumthings wrong
good to take everything back to standard to find the prob :)
hope it helpz
Edited by Zas)-(
https://www.sau.com.au/forums/topic/140077-miss-fire-bad/#findComment-2611930
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
    • Assuming your brake pads are not worn right down, I'd add a little brake fluid. Is there any sign of a brake fluid leak?
    • Hello all,  I need of some help. On my drive home my handbrake light lit up and started flashing. When I got home I checked my handbrake sensor under the centre console and nothing seemed out of the ordinary. I have scanned my car via the consult port, no codes shown. Checked my brake fluid as well which is half full. Tried unplugging the brake master but it didn't change anything. Thoughts on what it could be? The master float doesn't seem to be stuck. My car is an 1998 ER34 sedan GT. No hicas but has ABS Photos below 👇🏾
