my addvice is to dump the factory coils for a set of vn/vp or mitsubishi ones
i fitted a set of vp coils to an rb30 about a week ago and it was running fine till the fuel pump packed up
and today a fitted a set of Mitsubishi Diamante v6 coils to my rb20 and it ran mint started much quicker and ran smoother more tourque and it runs the same gapped sparks as the rb coils
  • Replies 58
What sort of power/boost are you making on these after market coils?
If its near stock or still stock turbo on measly 15psi boost then we can't tell if it will work once the combustion pressures are considerably higher.
+ the non-stock look. For $520 delivered splitfires are the way to go.
where abouts can u get em for $520? Autobarn almost called the medics when they told me a new set of spitfires would cost over $1500 (cause i wasn't expecting more than $500~$600).
i got the exact same problem as you guys. gotta get this fixed up soon :)
$520.
Buy from Nengun (~2-3week wait), Perfectrun (~7day wait). (Japan)
You'd have to be silly to buy from auto barn and the likes. If you must buy a set in Aus grab a set from Slide. He sells them for $589 + postage.
has anyone tried my fix at all?
i just bought myself some sandpaper whilst getting new spark plugs. there cleaned and all, just havent started the car. btw my coils are silver and it doesnt come up copper like yours..whats the go there? coilpacks themselves have already been sealed with that silicon 401 i did a while back as well. so will get back with results tomorrow.
no idea on why theyre different. could be a series 1.5 or 2 thing.
if yours is neither then i wouldnt have a clue mate :)
  • 1 month later...
I have r33 GTS4 NON-TURBO and got a misfire as well, what should be the spark plug gap for my one? is it still 0.8mm?
ive got no idea about the n/a's mate. do a search in naturally aspirated performance.
Pulled my coils out and they look brand new but i still have a miss!
your plugs look pretty shagged mate. close your gap to .8 and throw some new ones in.
Pics arnt very good, they are gapped to .8 and only recently put in, but was missing before they went in anyway
  • 1 month later...
does the rubber boot connecting to spark plug just pull off?
i had the missing problem 2 at 4500rpm and did the whole tape em up trick and u beauty, not a problem!
in the last couple of weeks, since we have had this hot weather, one coil seems 2 be playing up when the car is at peak operating temp
u will be driving, and all of a sudden it feels it drops a cylinder
u put ur foot flat 2 the floor and it clears it self up, and then when at normal revs u can hear the miss again
by looking at the coil there are a few hairline cracks but ive already taped them and still doin it when at normal operating temp?? any1 had this drama??
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
