Hello all... this is my first time posting here but have been a regular visitor for a while. I've just been looking around trying to figure out what the hell you guys keep talking about lol. All my friends say I'm pathetic when it comes to cars so I've come to learn from the best! :) plz dont scold me when I ask stupid questions hehe...
btw got a very stock gtst, in dire need of a respray etc :D... Can anyone recommend decent paint shops around the place. How much will I be looking to spend if i was to go for a full respray or if i wanted diff colour? tnx in advance :)
https://www.sau.com.au/forums/topic/140400-greetings/
hey phr33ky you probably know more then me... I don't even know what your car looks like lol thats how bad I am lol
If you click on search at the bottom and type in Paint you should come up with a few threads... or you can go the hard way and click on the numbers and sift your way thru a heap of threads to find paint work threads..
Hi and welcome :)
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615780
cowley smash repairs in canningvale.
9350 5069.
ask for brett, and he will give you a price.
(i was quoted 7k for a full colour change to calsonic blue)
highly recommend their work, its not the cheapest but its an excellent job, infact im going back there on saturday to get more work done. :)
ps: hi!
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615786
hi mate
if you want something a bit cheaper heaps of people recommend ATEC PANEL AND PAINT.. they seem to be doing alot of imports for PAS coming up you can try them out i went and saw their workshop and they seem to know what theyre doing so the info is
11 pratt court maddington
94520837 or mob 0432367982
www.atecpanelandpaint.com
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615833
9350 5069.
ps: hi!
agree!!
i had work done on my r33 there. they brought my nismo front bar back from the dead. there work is pure quality
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615868
7k jesus.... I was ready yo pay 5k, but if you guys say they do a top job I guess I will have to think about it. thnx
it all depends what you want.
best to give them a call, and go take your car down so they can have alook every car is different so it just depends
(for example you may need/want them to remove pin dents etc etc)
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615916
You mean Cannington mitchy? haha sorry just had to correct it, yeah give Brett a call he seems like a top bloke im sure he'll look after you.
Hey tiesto is ATEC a new workshop ? Never heard of them before....
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2615953
it all depends on what you need done. :no:
that 7k was entirely stripped, everything resprayed in calsonic blue, but my chassis is very straight, so there is only 1-2 pin dents to pull.
it depends on the colour you want too, calsonic blue isnt a cheap colour, whereas a more common, similar blue would have cost me 6k perhaps?
give brett a ring, he is more than happy to have a chat with you, and tell you exactly what is needed.
perhaps i do mean cannington :laugh:
i always get the two mixed up.
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2616443
$1500?
whats the quality like?
and do they do door seals, etc etc? or just external spray?
iv seen them for this price, its usually not a change of colour but the same colour to freshen up your old paint, and doesnt include engine bay door trims etc, if im wrong then ill get a respray aswell lol,
https://www.sau.com.au/forums/topic/140400-greetings/#findComment-2618696
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
