thats a bit higher then what i can get the parts for, but most people these days pay retail for most gear.
yeah os twins are around 2.5k new. 1200 is for a jim berry clutch (what ive got to go in the gtr, he said it'll hold me to over 1000hp, it looks like i'll be seeing how real that claim is)
random question, how many horses ur 32 have?
A viper? lol... Yeh they are tough. But I would take the rx7 or the R34 before a Viper.
id only take a viper if i had 100k to spend modifying it. mmm tt kit *strokes beard*
$3500 for the "and the likes" eg: HKS quds with carbon plates ect.
Jim berry is rather awesome indeed.
im a believer of u dont need anything more than a twin plate. all the jap twins/tripples/quads are f**ken sheit, they need the extra plates just o hold damn power. plus tripple/quads just kill boxes lolz
Thats why you don't run stock gear sets :sorcerer:
hahaha "Its as stupid and as wonderful as owning a pet elephant" what the hell? top gear needs to reconsider. and yes, still want one haha
Tag along on an SAU meet in Brisbane, I'm sure a GTR owner will take you for a drive
yea i will do in 6months when i get my R34 GT-T. will be goin down to the tracks in brissy, looking forward to it heaps.
Edited by Darkness_Ryda1
zilch atm. is getting all the right gear for 800+
More then my old one (which doesnt mean shit to you i know) Shane you make me cry, I need to out do you :)
haha i highly doubt it :P
i spoke at length with theo on friday. i shouldnt have done that :(
haha i highly doubt it :)
wow 800+ nice work. you got to skidpan or anything like that?
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
