you dont NEED a wideband afrg. they are hell expensive and tuners use them. just leave it to them. but your standard narrow band gauge gives an indication of possible problems. its not worth paying $600+
as an eg, i have, afrg, boost, water & oil temp, oil pressure, fuel pressure gauges
I'd get gauges in this order, boost, oil pressure, oil temp, water temp, afr an so on.. and try get a gauge with a warning light or a preset you can set the ' max ' of somethng and it'll flash or alarm, they're the best, my apexi el boost gauge lights up red if the car overboosts, which is great insurance as i'm usualy watching the road when i drive..
ull need a wideband afr gauge or dnt bother. volt gauge is gay.
i wanna get a inlet temp gauge next
To be realistic... I wouldnt even bother getting an AFRG....You'll know if your car is running lean or rich anyway.. Well i can tell.
Go with Dyna's suggestions.
as i was saying they are pointless unless they are accurate wideband gauges.. :P
Tell that line to your engine builder.."i knew my engine was running rich just before i saw a piston inbed itself in the bonnet !!".
I dont believe that for a second.You might be able to get a idea but throu listening but you dont know exactly what your air/fuel ratios are...
Ah in most cases you cant unless you have a meter or gauge. you might be able to hear an audilble knock or ping bit the damage is usually already done.i wouldnt rely my hearing on a modded import with a bit of boost and timing.
Get a stoich guage there only a 160 dollars approx.. maybe cheaper these days.
u dont necessarily need to be running lean to be pinging/knocking...large amounts of timing can do that on its own
whch is waht I have been saying for ever but no one beleived me
till my car hit the rollers ha ha
i based my above assumption on ur car lol
its all smoke n mirrors until u see real proof...much like marki's posts :)
its all smoke n mirrors until u see real proof...much like marki's posts ;)
bahaha as if fool. ginger please
For the first time we agree. :)
yeah bro i knw my shit u just dnt like my SR.. ill prove u all wrong haha
Anyone gonna be out tonight? The weather looks like crap..
I'll be out once i've bed these in ;)
ohh la la.. what brand..
and what pads u running.. im looking at upgrading pads..
the coilovers look like HSDs teins are full green
I'll probly like your sr, and props for building one up, but as for talking about it all the time like verbal diarrhea ;)
Coilovers are HSD HR's with 5kg/front 4kg/rear springs, perfect for the street, but still firm cause they're the track spec damper..
Disks are 343mm two piece DBA5000 series, ferodo 2500 pads, custom unique autosports caliper spacer, motul RBF600 fluid, calipers serviced/new seals.. :)
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
    • FYI: Racebox RE7R Custom Tunes Released!   https://goracebox.com/.../2017-infiniti-q50-q60-re7r-tcm...   FOR GEN 2 (21+) VEHICLES, PLEASE SEE NOTE AT BOTTOM See more   But whomever tuned your car is the tuner you should go back to, AMS, Sonictune or BT Tune....
