i know of 3 ppl losing there licences.. for apprent noise and defects that arnt herd of.. and all 3 are mechanics and another dude i know just got done for noise smoke and more defect's that he hasent herd of but stupid thing is... all my mates drive sensable and almost stock cars
haha hahahaha hahahahahahahaha....... sorry I couldn't contain myself!! Sensible you say? :woot:
lol nice find daz....thast funny
i know this is a skyline forum but if any of you guys know anyone looking for a turbo kit which has done less than 7000kms to suit a sr20det i have a
GT3071 genuine garret
manifold
braided line setup
wastegate
dump pipe
intake pipe
front pipe
all gaskets
nismo 740cc injectors
makes a good 250 to 280rwkw
Edited by Sr PWR
Do any of your mates drive something like this....
http://www.carsales.com.au/used-cars/priva...82&trecs=70
If not they should lol they will win shows, have a read lol such a weapon!
WOW!!! if i had the money to waste i would buy it just to set it on fire infront of the guy. it makes teh fulleh sik fast n furious cars look almost normal.
    • Hi. This is just my curiosity because iam sure the tuner figure something out...but either way i want to ask. The "problem" is that the Nistune ECU (Stagea FW and RB25DET NEO from Stagea) sees many times the speed than the speedo does(he says the speedo show 120 km/h - correct speed and the ECU shows like 510km/h ) I told him that this car/tranny getting speed from rear diff. If iam not mistaken the RB25DET NEO "need" to see tranny speed sensor? (my tranny has the plug for it). So couple of "question" If he connects/wire the speed sensor to the tranny...are the signals gonna intervene and if...what if he disconnects the rear diff one and the speedo stops working? Or the "new" sensor from the tranny "take over" and will not going need the one from diff? As i said i know he figure/get that done...iam just curious to know what are the solutions 🙂
    • Your IACV is set to idle too low. You need to adjust it via the screw Duncan mentioned. From memory it should be 650rpm with the valve electrics unplugged. What is it trying to idle at with the IACV plugged in?
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
