Spotted a skyline cruise :D
Ya's woulda seen me walkin home in my woolies uniform as ya went through beerwah. . . some seriouslly nice skylines.
Out of curiosity the silver R33 at the rear of the line what exhaust you got sounded very very nice as you went past.
Wish I coulda come, once I got the license i'll be there. Car will hopefully have around 4k of addons by then too :P
Damn, I only just read about this cruise.
I would have loved to have joined in. I replaced my fuel pump on that day and went out for a high spirited drive through Mooloolaba. No more lean problem YAY!
Next time guys.
Hey all new to the coast, just moved from SA. I drives a white laurel around. Keen to meet some new import ppl. Sux not having a friends network involving cars hahaha. Spewing bout missing that car cruise would have been fun/..\
Nice, what year is it?? I don't know why Honda stopped making them....
I just sold my VTR250, shoulda gave me a yell I woulda done a good deal for ya!
John, I haven't seen ya on the forums before so g'day! I like ur avatar too!
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
