Hey soon i am going to be doing my injectors and turbo and what not, and i was just curious, i have done my research and the manual sais to drain the coolant to take the top half of the manifold off? Has anyone done this job? How hard is it? What tools are needed? Is it time consuming?
Thanks. Phill.
https://www.sau.com.au/forums/topic/140919-taking-off-top-half-of-inlet/
draining the coolant is for when u take the cooling lines off the throttlebody/top half of manifold, u will need to remoove your crossoverpipe,throttle cable,all hoses/electrical earths, basicaly anything connected to the top half of the manifold, then theres a series of long bolts laying under the bottom section of the manifold, which transfer to the top. take em out then give the top half of the manifold a tap with a soft faced hammer to release its grip on the gasket, then its off! :sick: it took me no more then 30min, but im a mechanic :sick:
Edited by dead32
The first time i done injectors i didnt even take off the throttle body, the second time i did and it was much easier. If you are only taking off the top half of the manifold to do the injectors i wouldnt bother and just take off the throttle body as it gives you plenty of room.
i am a mechanic too, but only an apprentice :D so would just taking the throttle body off be enough to take all six injectors out? i was thinking the whole top half. With the coolant lines, wont you just be able to block them off rather than draining all the coolant?
Im trying to grasp how long this will take me and rob from creatd.. I was kinda thinking a whole week to do injectors ecu tune and turbo. Ecu and AFM i already know what to do, turbo im not too sure about, rocker cover gaskets i know 100% and plenum i kind of know whats happening.
Edited by LTHLRB
you can actually replace the injectors without removing the TB or the top half of the plenum. once the fuel rail bolts are out you lift and slide the whole assembly forward.
the hardest thing to do is get to the clips on injector #4 & #5.
I am about to replace the injectors and this time will remove the TB as i think it will be easier.
wouldnt worry bout taking apart plenum.
have changed injectors in a few rb20s and only took off throttle body.
dont really need to drain coolant. just unbolt the tb and unclip lume parts. pull off the coolant lines and just let them drain till it stops (alot less than draining whole lot) just make sure no coolant goes in the holes while the injestors are out
pretty easy job mate, just fiddly (esp. clips) should take bout an hour to change injectors.
maybe a little longer for your first time
i wont be doing it myself. I will have someone who knows rb25s like the back of his hand helping me, so shouldnt be a problem, i just wanted to know the best way to take the injectors out. :laugh: thanks heaps.
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
