I thought it about time to do a DIY for removing/replacing/upgrading injectors in a RB25 series engine. These photos were done my my Series 2 R33, but it should apply to most RB's I expect
Contrary to some posts I've seen, there is NO need to crack open the intake plenum to get to your injectors You only need to remove the AAC assembly and throttle body (and possibly FMIC piping).
The entire process should take you ~2 hours depending on your confidence/skills.
1) Remove AAC assembly. There is a DIY thread (HERE) on this but in this case, you only need to remove the AAC from the manifold, not pull it apart. Remove 3 hoses from AAC (circled in red) and loosen 3 bolts that hole AAC onto the manifold. There is no need to remove the hose from underneath the AAC unless you intend on removing and cleaning it.
2) Remove 3 bolts from AAC assembly. One bolt is circled in blue in above pic, but the other two are hidden underneath. Swing AAC away to the side. If the AAC is dirty inside, I suggest cleaning it as per AAC cleaning thread above.
3) Remove metal intake pipe. Remove 2 bolts from pipe bracket and loosen BOV recirc pipe (RHS of pic). Undo clamps that connect intake pipe to the throttle body, including one small hose that connects directly above the throttle body. Move intake pipe away from throttle body assembly.
4) Remove 4 bolts that hold the throttle body on and remove three other hoses (circled in red)
5) Undo a multitude of hoses (red circles) and unbolt the two bolts circled in blue. If you have a FMIC kit, take this opportunity to remove the pipe that runs over the radiator fan. You won't be able to get the injector rail out otherwise.
6) Undo 3 bolts holding the injector rail onto the manifold. You will be able to get to 2 of these with a ratchet, but one will need a spanner. BE CAREFUL - each bolt has a plastic spacer between the injector rail tab and manifold which can be easily dislodged and lost. Remove these and keep for when you are bolt the rail back on. Check (if you live in usa): Costco Weekly Ad, or Supercheap Auto Catalogue.
7) The injector rail will be able to be removed now. BE CAREFUL AGAIN - Each injector pintle is inserted into a rubber ring which can also be easily dislodged. DO NOT lose these. After the rail has been removed from the, reach in and unplug each injector (you kind of need nimble hands for this). Carefully remove injector rail by lifting and sliding out towards the front of the car.
8) For each injector, remove the two screws (with Philips head) from the injector cover and take off. These screws will more than likely be tight.
9) To remove the injector... If you don't have an injector puller (which most of us don't), the CAREFULLY insert a screwdriver wrapped in rag into the hole at the top of injector and lever it out of the rail.
10) To fit injectors into rail, put a small amount of grease on the o-ring and place injectors into rail and place cover on the top of it. Only use rubber grease as some industrial greases will eat rubber and that can lead to disaster. Don't try to push injectors into rail, as the cover with push it into place as you tighten the screws.
11) Put rail back into engine bay, ensureing that rubber pintle surrounds are in place, plastic spacer rings for the rail bolts are in place, injector plugs are plugged in, all hoses and clamps are replaced and tightened.
Thanks for reading!
-Alan
Edited by MearCat
  • Like 2
Thanks Alan just doing mine so this guide will help alot
In the pic above i want to remove the part in the red circle so that i can get the fuel rail re-dipped mine looks bad should this part just pull out.
Also was the fuel rail you used off an rb25de non turbo model
Excellent write up - this will come in handy for me soon, as i'll be replacing a couple of injectors on my RB20 - hopefully not too disimilar.
Cheers,
Steve.
R32 fuel rails are slightly different, at aleast on a GTR they are. But you wil be able to use this toot for getting at the fuel rail at least because you have the over the engine plenum intake.
Gotta ask how the hell do u remove a screw that the head has been fully burred out of one of the pintile caps holding the injector in place best possible method.
Cheers Adam
Cheers Adam
But a screw extraction tool if there is no other way to get it out. Bunnings etc sell them.
Or you can cut a slit in the top of the head and use a flat head screwdrive to pull it out.
  • 4 months later...
10) To fit injectors into rail, place injectors into rail and place cover on the top of it. Don't try to push injectors into rail, as the cover with push it into place as you tighten the screws
Thanks for reading!
-Alan
Can youn please re add the pictures please...................?
  • 1 month later...
Cheers Adam
Yeah, these babies were tight!
Not enough down pressure or crappy screwdrivers and GONE!
I ruined 2 screws out of the 12 so it's prett easy to do.
Grabbed my trusty hacksaw and sawed a slit in the top, straight out with a flathead screwdriver :)
Awesome writeup mate,
Got quoted $320 from the tuners to install injectors for me..
You have saved me $320
Thanks mate.
Agreed, awesome write up.
In and out took me a touch over 4 hrs for a 1st timer.
$320/4 = $80 an hour.... Cool ! Feels awesome to save that cash!
It's like getting a free boost controller! LOL :P
Grabbed my trusty hacksaw and sawed a slit in the top, straight out with a flathead screwdriver :yes:
It's like getting a free boost controller! LOL :domokun:
For anyone else giving this a go...To avoid rounding the screws that hold the injector "hats" in place, stick a stubby screwdriver in the screw and give it a good whack with a hammer. This should break the seal on the screw and they come out easily.
  • 1 month later...
  • 2 months later...
  • 3 weeks later...
Do you need to lube up the rubber o-rings before putting the new ones in? If so what lube do you use (no jokes please)
Not sure whether it's mandatory or not, but I just put a tiny amount of generic grease around mine.
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
