  • Replies 47
Posted Images
Where did your friend hear that from?
Rhere's defect stations as the weather warms up for years.
Years back when I was in my teens from around 15-16 (~10years ago) they used to sit down both Hindley and Rundle street. Occasionally on Anzac highway near the tennis courts.
Those were the days.. lol
Hands up for those that remember the car park at the end of Anzac highway Glenelg. :P
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2627975
Not sure if we are talking about the same car park. :yucky:
Originally there was the car park right at the end of Anzac highway, like right at the end where the roundabout now is. That was shut down ~10years ago (1995-1996) and all there was left was magic mountain car park, which in comparison was gay. :sick:
Every weekend the car park at the end of Anzac';s would fill with hoons, burnouts packs of cars leaving to run up anzac. Given a couple of hours which was strange considering it always happened and the cop shop was 100m away the police would come in shut down the car park and defect those left. :kiss:
Was quite interesting for a young lad just getting his license.
I've attached a pic of where it was. See the blue square.
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2628474
I read the article your friend did too. Apparently it's part of the crackdown on crime in the bay, not sure what a defect station has to do with binge drinking hooligans on jetty road though.
Anyhow, expect an increase police presence down that way when it heats up.
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2628661
lol cubes you must be as old as i am .used to go down there with my lj torrie with a 327 chev in it someone would see the cops comming and people would run to there cars trying to escape b4 they arrived .the old smithfield road house was another great hangout as well
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2629051
well being phat could get you in trouble which isnt worth it. thats why i took mine out when i got my alarm. other way is if you want to use the tt, just dont pull up the hand brake when you turn off your engine.
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2629421
Yeah that's a good point duc. I've just been hitting the tt kill switch, but it's something i should think about when i redo my console - was in the middle of relocating the gauges, tt, shift controllers, etc.
On another noted... police can't go through your car without a warrant right? Or unless they see something that would warrant a search.
Edited by Howie
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2629576
You are right Howie... But what can you do if they said that they "suspect" that your car has some illegal mods? You still have no choice but to let them check out your ride man......
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2629615
Nice LJ with a 328 in it. :)
I can't imagine such a thing happening in this day and age.. I was surprised at times how long it took for the police to rock up; ppls would drop a bit of oil, washing detergent or what ever it was and burn out after burnout would occur as ppls left on those warm nights.
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2630601
i originally had my tubro timer mounted on the panel under steering wheel, but was always shitting myself and taking it off when there was a breatho and yanked it off.
I now mounted it in the little tray under stereo, and the plan is if someone checks my car to just turn it off and put my phone in front of it. if my phone gets moved i might be screwed, but my car looks stock from inside so i rekon my chances are good :)
https://www.sau.com.au/forums/topic/141134-defect-stations/#findComment-2630665
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
