Well my real name is nathan
i recently spent a day at autosalon with skylines australia
sadly dont have my licence yet get my learners jan 3rd :) poor thing my bday is 3rd july and looks like ill get those new laws
saved nearly all my money from working so i hope to have a nice first car
ill stick around these forums and hope to see you guys and girls around more often ;)
https://www.sau.com.au/forums/topic/141250-my-intro/
  • Replies 40
Welcome "Mini Choy" hang out with us and you will hear words like; Hymen, boobs and blowoff valves. You will lean lots of things to help you be cool around the school grounds. Plus when its your formal you will have a nice skyline to go in.
Peace out Mini Choy
Chris
https://www.sau.com.au/forums/topic/141250-my-intro/#findComment-2634627
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
