  • Replies 209
oops an my bad its not sweat its sweet!!!
um well its actually anutha name for pot, but its also a great song by black sabbath and marlyn manson does a good version too, i think metallica has a version as well ( now im goingto have to go thru my cds) but basically its one of my nicknames, the one that means the most to me anyways...and ch33ky wasnt available
Yeah great song...Godsmack did a version NIB II.
Looking to get a plate for my car TEXICAN....Being from TEXas and being part mexICAN :mellow:
Looking to get a plate for my car TEXICAN....Being from TEXas and being part mexICAN :D
yeah i got all the godsmack cds..my bf got me onto them a while back...
he just got a new black 32 wohoo...its our project car, absolutely no mods done to it, but we doing it up. its going to be a sleeper for a while and then sumtime next yr get the carbon fibre and mags ect, atm just doing the engine and suspension ect
  • 3 weeks later...
I got QRI05E = Curious... had it on my SSS since i got my L's so thought to keep them... lol
Here are a couple nice plates i considered getting that are NOT taken in NSW:
ZZZTSH = BOV sound
1VAKND = One of a Kind
NOTLEB = perfect for an RB powered Holden Gemini LOL :P
I have seen some nice ones in Syd:
I8AV8 = I ate a V8
3ENTRY = Free Entry
LTSRUN = Lets Run
DUZNGO = Dosen't Go
GMEOVR = Game Over
Cheers
im ova my plates, i like them, but too many cop hastles, you get done for high powered once, they will just keep pulling you over for a quick buck.
if anyone wants them, send me a pm.
Edited by LTHLRB
I've got EVIL TWIN
In case that doesn't make sense, they're on my GTR
That RB26 sticker rings a bell, I think you were at the licence centre when I was applying for mine last month. Or maybe the company that made the sticker made more than 1 to see a profit.
More than likely - the City West licencing centre? I was picking up my plates last month.
That sticker was on the car when it came from Japan. It has "GTR Magazine" on it, so it must have been a give-away in Japan.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
