Nismo spoiler
55 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey guys, I'm planning to get rid of the nismo spoiler that came with my car soon.
I'm tossing up between taking the whole thing off, or just getting rid of the corner pods instead. What do you guys think?
Also, anybody know what type of rear bar is on my car? I've never seen one like it before.
Cheers.
https://www.sau.com.au/forums/topic/142319-nismo-high-wing-sick/
that wing is hideous and its the worst thing to ever have the name nismo, please not only take it off, but burn it, so no other poor soul has to buy it :(
p.s. as u can tell i dont like it, but if u do...you could keep it i guess :S
p.p.s. lucky bastard, P plater in a 34 :P
haha y not take the wing offbut leave the corner pods - go for the FA-18 look.....
or just go the spoilerless
p.s. is that a MR2 i see in front of ur 'line? with a P plate?? man i thought i was spoilt. lol jk
Edited by Basti
It ain't nismo.. it's altia. I had it on my ride, and got it removed pronto.
Btw, love your rims.. if they're the nismo 18's.. they were exactly what i was after before i spotted my current gtr rims.
Edited by Howie
Nah the R34 doesn't look good without a wing I reckon, change it for a normal wing.
How much did you pick the car for by the way? Looks neat, esp with the LMGT4s. :huh: Oh and I think that rearbar is the true Nismo rearbar, not the Atila ones with Skyline written over them.
2 questions:
1) Why do you have a GTR badge on your GTT?
2) What's going on with your frong grille? CF? Looks swanky :laugh:
Dang that front lip looks familiar :)
Hi Stan
I like you website, very informative and nice gallery...yeah front lip looks familiar.
Anyway i just like the badge since i had them awhile ago, best place to stick it is on the car. However I plan to get the real thing next year if the price is right...finger's crossed. If not then i'll probably go for the RB26 engine conversion still on FR.
As for the front grille, the black (sprayed) makes the front more menacing..compare to the white finishing. Anyway most of my mates here done the same thing so maybe it's more like our group signature when it comes to white GTT's.
Btw ur rims is awesome too....Cheers! :laugh:
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
