I own a bell something, paid a decent price as well. It now lives in a draw in my garage waiting fro me to decide wheather to reinstall it. I dont know; i think these things are like weight benches...you get all enthusiastic about the purchase and when you get them you use them for a while then they end up as an expensive dust collector. I found that even on "country" mode i still got a lot of false alarms. I prefer to scan the road side, remember the hot spots, watch the traffic and just be a bit more selective in when i stretch the GT-Rs legs. Still...its you cash >_<
Buy one local...not sure about OS radar frequencies. Best check with legallity of owning one and where to place it on your car, each state is different
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2650715
Yeah i've heard a lot about those BELLS one, i even heard of one that work with just plug in your cigi socket.
The oversea frequencies, i have no idea but its not my $$ either :woot:, its for a mate oversea.
Thanks
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2651007
Khoa
I had a Bell 900i when I lived in Perth. Radar detectors are legal over there and are great to have. Most places in WA stock them and you can buy them legally as well.
Over the years ive seen a few of em work and the old stuff is shit and gave a lot of false readings.
Id say anything new these days would work perfectly. They cost anywhere from 700 to 1000 dollars.
Ohh and Laser - yes radar detectors have ALWAYS picked up laser so I dont know what ur on about.
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2654540
they sell them at tandy/dicksmith
uniden brand they are on special awhile ago for $190 reduced from 300 and something.
if you want to sus some out check out american ebay, www.ebay.com they have alot to chose from so it is a good place to compare brands
https://www.sau.com.au/forums/topic/142368-radar-detector/#findComment-2670838
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
