Hi guys,
Just thought i would let you know that
Canberra Cruises have organised a dyno day
at Jakes performance on Sat 18th November.
If more than 30 cars go it will only be $40 each.
leave a post or pm me if you are interested
cheers,
Matt
https://www.sau.com.au/forums/topic/142557-dyno-day/
OK
Its starts at 9am this saturday at jakes.
cost will be $40.
let me know by friday if you are definately coming
I'm going to be a spectator this time as the car is not tuned properly and i don't want it to go bang while on the rollers. Got it booked in on the following Monday for some tuning. Maybe next time.
https://www.sau.com.au/forums/topic/142557-dyno-day/#findComment-2667390
I will definitely be there, is it best in best dressed, or organised timings? cheers.
It will be first there gets first run,
but as people arrive they will be added to a list to set the order
and to avoid people cutting in the line
https://www.sau.com.au/forums/topic/142557-dyno-day/#findComment-2677294
was nice to see so many fords lol..... Its all good Kate, Mat and myself Represented the Jap street performance cars.
Also that mighty Dawoo that pulled 51kw at the front wheels good stuff from the Dawoo.
lol, don't forget the little ford (laser?) that pulled a massive 35 kx at the front wheels.
Was a good morning, thanks Matt for letting us know about it.
https://www.sau.com.au/forums/topic/142557-dyno-day/#findComment-2682757
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
