looking at your results roy, it would appear it could well be a 20 still.
is there any way to confirm without pulling the head off?
Simons turbine is now a bit smaller then yours but the one that i put in to replace the oversize was a Biagio race shaft.
Same major diameter,exducer but a little bit smaller on the inducer and a change in fin design. :angry:
And he is only running 15.5 psi so there should still be about 10-15rwkw in it after the injector upgrade and a little more boost.
I cant wait to see some results with camshafts and cam gears, They should well and truely break 250rwkw. :huh:
  • Replies 231
Dyno run as per request. Sorry it took a while, couldn't remember simons rego.
There is definitely more in it. Simons tune is extraordinarily conservative because he thrashes the life out if it and it's on the injector limit.
One day when i have more time i'll put it back on the dyno because i'm sure i can get it to spool quicker with some timing adjustments.
These turbos seem to come to life at around 16-18 psi.
Edited by TSL
What size cams would you recommend Aaron, when using the rb25 standard highflow? As you know I bought a highflow off you and am happy to folk out for cams but i simply dont know what to get! I even happy to get a custom grind if needed...
Edited by Smooth
An amazing result with a small capacity engine. Great stuff! :sorcerer:
The RB20 is obviously a little doughy down lower in the range, but you've got a very strong mid range that holds and holds. Doesn't like to drop off after the peak either.
Boost control looks exceptionally good too... :wave:
Used in its intended environment (drift??) that thing should be very useful.
Either the Tomei Poncam 256 ex 8.5mm or the HKS 256 ex 8.8mm
They open up the top end on any car like you wouldnt beleive :wave:
  • 3 months later...
Just a bit of an update...
I have just set my exhaust cam gear to -4 deg and added 3 deg of timing between 3200 and 3600 and the car now spools a 2~300rpm earlier. I also have reduced the timing to 18deg from 4200 to 6000 19deg between 6000 and 7200 just to be on the safe side as I am now running 19psi.
Going by the fact that I have had to add 13% more fuel from 4000 onwards to keep my AFR's at 12:1 I am guessing I have come VERY close to adding my car to the 260rwkw RB20 thread :)
JEEBUS>>> keep your pants on.... really this thing as BALLS...
when running this sort of boost the cam gear really shines and so does the hiflow.
I am not going to get a chance to dyno it for at least a month but i don't need to the tune is perfect and it would really only be to confirm a number. I really am having difficulty believing just how well these turbos perform, I was thinking of pulling the RB20 and going a 25 or even 30det but I really like the 20 with this much power.
Damn thats some big differences...
Looks like ive got my next mods sorted then! Cam gear then another tune from you mate if thats do-able, might just take the trip down to the berra and get you to do it if youve got a day free?
Im just having a problem with my car at the moment, i think its called TRACTION!
RB20s FTW!
bit more responsive down low and just wants to go go go untill boost arrives which is nice... but i dont think it was pinging after all, (even though i got a few people to confirm that it was) pretty sure it was the coil packs in the early stages of dieing!, borrowed some spitfires for now and car seems fine.....
so might exhaust cam gear it and crank some more power out of my reliable RB20
  • 1 year later...
hey I'm new to this forum iv been reading around in here for a few days. is there an available bin directory or anything like that. so i can get a close base map to tune off of. I'm running a R Rb20 with a hybrid turbo i built to4b compressor with a sc61 hot side fc rx7 center and exhaust wheel trims are .60 .82..... rite now its siting at 1 bar but i got a dead spot around 6500. the only fuel mod i have rite now is a fpr. my ecu has been socketed and slightly tuned but that was for the stock turbo. any help me here would be much appreciated..
Jesse
sounds like an interesting combo, but you should really have it tuned rather than getting a base map unless you know what you are doing.
i can help you out with a base map if you want one. pm me your email address
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
