Hi there, I've searched the website but just found posts on which ones brands are good, panal vs pod etc..
I understand what pod air filters are now, and Skyline uses panel air filters as stock.
I was just wondering if I wanna get a pod filter, how do I install it and if I wanna change the panel air filter, how to do install that as well..
cuz i opened my bonnet today and I can't find a place to put a pod air filter.
Thank you guys!
(...and girls..)
p/s- are pod air filters illegal? i read some mentions of us getting defected by the cops if pulled over n they got us to open the bonnet
Edited by HolyEvil
https://www.sau.com.au/forums/topic/142664-air-filters/
- if you get a pod filter. youve gta replace your stock airbox. basically take it all out and leave the air flowmeter. then you jus bolt on your new pod to the air flow meter & mount the air filter stable. (assuming its bolt on, or u may need an adapter. apexi power intake is the popular choice for a pod & its bolt on)
- if you wana change panel filter. just lift the top lid and replace with the correct model air filter and whatever brand you intend to put in. (k&n hi flow panel filter the popular choice for panels)
- pod filters are illegal in NSW. unless enclosed. other states may vary.
hope that helps mate
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2657651
In case that's not clear enough the standard airbox has four spring clips on the sides.Just flick them back and the top will lift off.You can then lift out the old panel and drop in the new one.Piece of cake.Just make sure you put in in the same way up.
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2657892
what state are you in? different rules for different states. in vic you can have only one intake mod, either an aftermarket intercooler or an aftermarket pod. if you get a pod it must be of a paper base type not oil based like the k&n pods. it must be secured cant have it floppin around and you cant take out the air flow meter.
if you look at your air box you will see the air flow meter (afm) its the thing running into it with the plug hanging off it. id post you a pic but its not working for me. it bolts onto the air box with 4 bolts. the air box its self is held in with 4 bolts too. if you want to put a pod in remove the bolts to the air box first then undo the hose clamp that attaches the afm to the rubber pipe thing. once you have done that you can pull out the whole air box with the afm attached to it. unbolt the afm from the box, bolt on your pod, slide the afm back into the rubber pipe thing do up the hose clamp and your basicaly done. you just need to secure it so it doesnt flop around which can be done any way you want.
or unclip the clips pull out the panel filter and put a new one in then do up the clips :laugh:
(this is for an r33 by the way but im guessing a 34 is the same)
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2658828
post-25470-1163125788.jpgpost-25470-1163125821.jpgpost-25470-1163125876.jpgive circled the relevant areas in the pics. (not very well) you may have the snorkel for the air box still on. it just unclips. make sure when you buy a pod it comes with a plate like mine i think if you say its for a skyline it may come with it but not sure didnt buy mine came on the car.
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2658913
heya mate.. it's circled well enough, the plate that you mentioned is the black bit with the jap writing?
what's a snorkel?
cheers
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2660889
hmmm hmm hmmm
or unclip the clips pull out the panel filter and put a new one in then do up the clips :P
this sounds much much better =)
btw what's an aftermarket intercooler and what does it do?
thanks
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2660900
;):rofl::rofl::D
hmmm hmm hmmm
thanks
Oh dear.Well at least you're not scared to ask.Aftermarket simply means not standard.The intercooler is what cools the hot air from the turbo before it goes into the engine.It's like a radiator but the intake air passes through it instead of your engine coolant.Scuse the rofl's but it really is a funny question.
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2662333
;):P:):(
haha don't worry mate.. anyone can have a laff.. hehe even i do... but hey i got my answer =)
oh..does a non turbo car use a intercooler? =)
(some chick must be out there slapping her forehead with my questions)
cheers
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2664811
A non-turbo car does not use a intercooler.
We all have to start somewhere mate, most of the ppl on here unless from a mechanical background or with ppl to ask wouldnt of know what alot of things were or ment when they first started out. Its what being a car enthuisist is all about, its all a learning curve.
as the old saying goes, ' There is no such thing as a dumb question '
Also with a pod filter, its always best to try and enclose it, so it doesnt suck all the hot air from under the bonnet into the engine. Also try have some sort of cold air coming from outside the car (CAI - Cold Air Intake), as this will aid in actually having the pod filter in the first place.
Edited by Acer
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2666644
Oh yeah one thing to watch if you do go for a cold air intake duct is not to run it too low.Can suck up water if you hit puddles.Not good.One mod that some people have done with success is to holesaw some holes in the steel beneath the standard air box and cut matching holes in the plastic.Easy,cheap and no defect notices.
Acer is right.We all gotta start somewhere and none of us know everything.Cheers.
https://www.sau.com.au/forums/topic/142664-air-filters/#findComment-2666786
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
